Continua la discussione da How to get cinnamon desktop?:
Oggi ho fatto un altro tentativo per MATE Desktop.
# urpmi.update -a
# urpmi task-mate
[details=Summary]
(medium “main”)
abattis-cantarell-fonts 0.0.16 2 omv 2015.0 noarch
adwaita-cursor-theme 3.18.0 2 omv 2015.0 noarch
adwaita-gtk2-theme 3.18.0 4 omv 2015.0 x86_64
adwaita-gtk3-theme 3.18.0 4 omv 2015.0 x86_64
cdrkit-isotools 1.1.11 20 omv 2015.0 x86_64 (suggested)
dconf-editor 3.18.2 2 omv 2015.0 x86_64
ghostscript-module-X 9.19 1 omv 2015.0 x86_64
glib-networking 2.46.1 1 omv 2015.0 x86_64 (suggested)
gnome-mime-data 2.18.0 19 omv 2015.0 noarch
gnome-themes-standard 3.18.0 4 omv 2015.0 x86_64
gtksourceview 2.11.2 16 omv 2015.0 x86_64
lib64archive15 3.2.1 3 omv 2015.0 x86_64
lib64blas3 3.6.1 1 omv 2015.0 x86_64
lib64exempi3 2.2.2 3 omv 2015.0 x86_64
lib64glib-networking 2.46.1 1 omv 2015.0 x86_64 (suggested)
lib64gtksourceview-2.0_0 2.11.2 16 omv 2015.0 x86_64
lib64gtop2.0_10 2.32.0 1 omv 2015.0 x86_64
lib64gxps2 0.2.3.2 12 omv 2015.0 x86_64
lib64indicator3_7 12.10.1 5 omv 2015.0 x86_64
lib64kpathsea6 20160523 3 omv 2015.0 x86_64
lib64lapack3 3.6.1 1 omv 2015.0 x86_64
lib64pyglib2.0_0 2.28.6 14 omv 2015.0 x86_64
lib64unique3.0_0 3.0.2 14 omv 2015.0 x86_64
lib64wnck3_0 3.14.0 1 omv 2015.0 x86_64
lib64xklavier16 5.3 14 omv 2015.0 x86_64
lib64xres1 1.0.7 10 omv 2015.0 x86_64
libgtop2 2.32.0 1 omv 2015.0 x86_64 (suggested)
librsvg 2.40.16 1 omv 2015.0 x86_64
libwnck3 3.14.0 1 omv 2015.0 x86_64
preload 0.6.4 15 omv 2015.0 x86_64
pygtk2.0 2.24.0 18 omv 2015.0 x86_64
pygtk2.0-libglade 2.24.0 18 omv 2015.0 x86_64
python2-cairo 1.10.0 10 omv 2015.0 x86_64
python2-gobject 2.28.6 14 omv 2015.0 x86_64
python2-gtksourceview 2.10.1 17 omv 2015.0 x86_64
python2-numpy 1.11.0 1.1 omv 2015.0 x86_64
zenity 3.18.1 1 omv 2015.0 x86_64
(medium “main_up”)
lib64gail3_0 3.22.9 1 omv 2015.0 x86_64
lib64gfortran3 6.3.1_2017.> 1 omv 2015.0 x86_64
lib64json-glib1.0_0 1.2.2 1 omv 2015.0 x86_64
lib64lightdm-gir1 1.22.0 2 omv 2015.0 x86_64
lib64lightdm-gobject1_0 1.22.0 2 omv 2015.0 x86_64
lib64poppler-glib8 0.43.0 2 omv 2015.0 x86_64
lib64quadmath0 6.3.1_2017.> 1 omv 2015.0 x86_64
lib64webkit2gtk4.0_37 2.14.2 1 omv 2015.0 x86_64
libnotify 0.7.7 1 omv 2015.0 x86_64
lightdm 1.22.0 2 omv 2015.0 x86_64
lightdm-gtk-greeter-common 2.0.2 1 omv 2015.0 noarch
lightdm-gtk3-greeter 2.0.2 1 omv 2015.0 x86_64
webkit2 2.14.2 1 omv 2015.0 x86_64
(medium “contrib”)
atril 1.14.0 1 omv 2015.0 x86_64
caja 1.14.1 1 omv 2015.0 x86_64
engrampa 1.14.1 1 omv 2015.0 x86_64
eom 1.14.1 1 omv 2015.0 x86_64
ffmpegthumbnailer 2.1.1 1 omv 2015.0 x86_64 (suggested)
lib64atril3 1.14.0 1 omv 2015.0 x86_64
lib64caja-extension1 1.14.1 1 omv 2015.0 x86_64
lib64ffmpegthumbnailer4 2.1.1 1 omv 2015.0 x86_64 (suggested)
lib64marco-private1 1.14.2 1 omv 2015.0 x86_64
lib64mate-desktop2_17 1.14.0 2 omv 2015.0 x86_64
lib64mate-menu2 1.14.0 1 omv 2015.0 x86_64
lib64mate-panel-applet4_1 1.14.0 1 omv 2015.0 x86_64
lib64mate-sensors-applet-plugin0 1.14.0 1 omv 2015.0 x86_64
lib64mate-slab0 1.14.0 1 omv 2015.0 x86_64
lib64mate-window-settings1 1.14.0 1 omv 2015.0 x86_64
lib64matedict6 1.14.0 1 omv 2015.0 x86_64
lib64matekbd4 1.14.0 1 omv 2015.0 x86_64
lib64matekbdui4 1.14.0 1 omv 2015.0 x86_64
lib64matemixer0 1.14.0 1 omv 2015.0 x86_64
lib64mateweather1 1.14.0 1 omv 2015.0 x86_64
libmatekbd-data 1.14.0 1 omv 2015.0 noarch
marco 1.14.2 1 omv 2015.0 x86_64
mate-applets 1.14.0 1 omv 2015.0 x86_64
mate-backgrounds 1.14.0 1 omv 2015.0 noarch
mate-control-center 1.14.0 1 omv 2015.0 x86_64
mate-desktop 1.14.0 2 omv 2015.0 x86_64
mate-icon-theme 1.14.0 1 omv 2015.0 noarch
mate-indicator-applet 1.14.0 1 omv 2015.0 x86_64
mate-media 1.14.0 1 omv 2015.0 x86_64
mate-menus 1.14.0 1 omv 2015.0 x86_64
mate-notification-daemon 1.14.1 1 omv 2015.0 x86_64
mate-panel 1.14.0 1 omv 2015.0 x86_64
mate-polkit 1.14.0 1 omv 2015.0 x86_64
mate-power-manager 1.14.0 1 omv 2015.0 x86_64
mate-screensaver 1.14.1 1 omv 2015.0 x86_64
mate-sensors-applet 1.14.0 1 omv 2015.0 x86_64
mate-session-manager 1.14.0 1 omv 2015.0 x86_64
mate-session-manager-bin 1.14.0 1 omv 2015.0 x86_64
mate-settings-daemon 1.14.0 1 omv 2015.0 x86_64
mate-system-monitor 1.14.0 1 omv 2015.0 x86_64
mate-terminal 1.14.0 1 omv 2015.0 x86_64
mate-utils 1.14.0 1 omv 2015.0 x86_64
matemixer-backend-pulse 1.14.0 1 omv 2015.0 x86_64
mozo 1.14.0 1 omv 2015.0 noarch
pluma 1.14.0 1 omv 2015.0 x86_64
python-mate-menus 1.14.0 1 omv 2015.0 x86_64
task-mate 1.14.0 1 omv 2015.0 noarch
task-mate-minimal 1.14.0 1 omv 2015.0 noarch
289MB of additional disk space will be used.
97MB of packages will be retrieved.
Proceed with the installation of the 98 packages? (Y/n)[/details]
Poi ho creato il file mate.desktop in /usr/share/xsessions/
con questo contenuto:
[Desktop Entry]
Type=Application
Exec=startmate
TryExec=mate-session
Name=Mate Desktop
Comment=Lightweight GTK Desktop
Inoltre servono anche i pacchetti murrine e mate-themes
# urpmi murrine
mate-themes benchè venga selezionato non si riesce ad installare (l’ho cercato manualmente nel repository indicato senza trovarlo)
Allora ho provato con quello di ROSA
Scaricato in locale e installato
[root@omlx-1077 Downloads]# urpmi mate-themes-1.8.0-2-rosa2014.1.noarch.rpm
installing mate-themes-1.8.0-2-rosa2014.1.noarch.rpm
Preparing... #####################################################################################
1/1: mate-themes #####################################################################################
Dopo qualche sma…nettamento (nelle varie configurazioni del desktop) ho ottenuto qualcosa di carino e discretamente usabile
Riferimenti: oltre alla discussione in inglese, questo bug report.
Il test è stato eseguito in una nuova installazione in macchina virtuale virtualbox della ISO 1077
