Hp-setup for HP LaserJet Pro MFP 4101fdw Failures
I am on OpenMandriva Lx rome 24.12 x86_64; Linux 6.12.6-KDE-1omv2490. I just downloaded the hplip program but I cannot get hp-setup to discover this printer.
I am multiple booting this distribution along with MX23, Endeavouros, Linux Mint and I have no problems detecting the laser printer. If it is a firewall or a ports issue, how to I go about modifying it. Thanks.
After running hp-setup, I get the following error messages:
HP Linux Imaging and Printing System (ver. 3.24.4)
Printer/Fax Setup Utility ver. 9.0
Copyright (c) 2001-18 HP Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
Searching… (bus=net, timeout=5, ttl=4, search=(None) desc=0, method=mdns)
error: No devices found on bus: net
error: HPLIP cannot detect printers in your network. This may be due to existing firewall settings blocking the required ports.
When you are in a trusted network environment, you may open the ports for network services like mdns and slp in the firewall. For detailed steps follow the link.
Troubleshoot Network Issues | hp's Developer Portal
Read:
ROME Release Notes
ROME Errata
Printing is discussed in Errata.
Welcome to OpenMandriva and our forum. This forum is for users of OpenMandriva Linux operating systems.
From the web.
IPP Firewall Ports
The Internet Printing Protocol (IPP) uses TCP port 631 as its well-known port. To allow IPP printing through a firewall, you need to ensure that port 631 is open for TCP traffic. Additionally, other ports such as 80, 161, and 9100 may also be required depending on the printer model and additional protocols used, such as HTTP, SNMP, and RAW printing.
There is a possible if not likely solution in ROME Errata. OpenMandriva does not install most printer drivers by default you have to install them. It is easy.
Hint: It does not say sudo dnf install hplip there is another meta or task package to install task-printing-hp. I do not know if that will help but I have no advice to give until that is done.
Had a similar issue with Arch. Try this command (if you have it connected to your router like I did) from your terminal.
hp-setup -i <PRINTER IP>
The Printer’s IP is displayed on the front panel.
Thanks. Tried your suggestion. As mentioned by others, hp-setup -i will not work with OpenMandriva. I have used hp-setup with many other distros and it always worked before.
Thanks Ben. I did a google search on HP laser printers and OpenMandriva but came up empty handed. Also, I browsed the wiki before posting. I will take another closer look into the wiki somemore.
Ben, task-printing-hp also did not work. After reading the Wiki some more, I use CUPS and got my HP printer to work. Just really want to thank all who chimed in to steer me towards my solution.
What error did you get? I just tried it on my box and got this error:
warning: No display found.
warning: GUI mode not available - switching to interactive mode.
error: hp-systray requires Qt4 GUI and DBus support. Exiting.
warning: Unable to connect to dbus. Is hp-systray running?
I got this running the operation through SSH, before I logged into the box.
Once I logged into the box and re-ran it, it reported “done” and the GUI shows the printer.
Please look at my original post where I used hp-setup and I listed the errors that I got when I ran it. In the past, with the hp-setup command on every other linux distro, my HP LaserJet Pro was set up automatically.
May I ask you what commands did you use to get your stated errors?
  1. ssh user@IP
  2. dnf -i IP_ADDRESS
The host computer wasn’t logged in to the Plasma user desktop, it was sitting at the SDDM log in screen.
Interesting. I did exactly your step 2 but it did not work for me. I don’t use ssh but that should not be an issue.
I set up mine with hp-setup, but it would fail to find it wirelessly. I change the default discovery method from mDNS/Bonjour to SLP and it went through like butter.
@Phr0stByte1
welcome1
Thank you - just testing out this distro. Much different than the Mandrake I started out on almost 30 years ago!
