Hi all.
Finally, I was able to sign up in the new OMV ABFarm. Now it came the hard part.
How to collaborate? I’m very newbie with this. I don’t know where to begin !
For example. As I’m an amateur astronomer, I use stellarium a lot. Actually, latest stellarium is version 0.14.2 (available version in OMV repositories is 0.14.1). I already got the source. I also found the GitHub page.
$ rpm -qa | grep gcc
lib64gcc1-4.8.3_2014.01-2.1-omv2014.0.x86_64
libgcc1-4.8.3_2014.01-2.1-omv2014.0.x86_64
gcc-4.8.3_2014.01-2.1-omv2014.0.x86_64
gcc-cpp-4.8.3_2014.01-2.1-omv2014.0.x86_64
gcc-c++-4.8.3_2014.01-2.1-omv2014.0.x86_64
$ rpm -qa | grep clang
$ rpm -qa | grep rpmbuild
$ cat /etc/release
OpenMandriva Lx release 2014.0 (Phosphorus) for x86_64
- What are the next steps?
- Libraries and packages to download?
- How do I do to generate 64-bits (as my system) and 32-bits versions?
- Should I compile the package from Lx3 or I can do the work from OMV 2014?
- Can be some kind of how-to be write?
Note: I cannot find any reference to Lx3 32-bits in the new ABF.
