What with ABF down and many testers reporting that they can’t install latest OM Lx 3 Beta thought I’d do this.
Using Robert Xu’s nightly builds here https://nightly.rxu.io/. I used 20151025.iso on hardware and 20141027.iso in VirtualBox. Here’s hoping this is helpful.
Boot in to Live
When you get to black screen enter virtual console and login as ‘root’
Run as root ‘finish-install’
To start desktop run ‘service sddm start’.
When you get to desktop there will be no menu panel so right click mouse and select ‘Add Panel>Default Panel’ or whatever panel you prefer.
Open Konsole, and type ‘su’ to become root.
Type ‘export $(dbus-launch)’ without the '.
Type ‘kwrite /usr/lib64/calamares/modules/services/main.py’ again without the '. That will open the file a root so you can edit it.
In kwrite go to ‘View’ and select ‘Show line numbers’.
Now comment out (#)lines 29, 55, and 56.
Save the edited file and quit kwrite.
Still in Konsole as root type ‘calamares -d’ and installer will startup.
This will install the latest packages, bug fixes, and working power management as of the .iso date.
Edit: 11/08/15 edited to add ‘finish-install’ and refine how desktop starts.
So let’s do some installing, bug reporting, and bug squashing. Bear in mind that with ABF down some bug fixes can’t be implemented until it is back up.
