How to install nm-applet (or similar)
I have checked the Resources category
ROME 25.06
i3
I am using i3 and try try to enable a network manager applet. In the past, I used i3 with ubuntu and my network manager applet was nm-applet.
The problem is that with OpenMandriva I cannot find a way to install it.
Tried both sudo dnf install network-manager and sudo dnf install network-manager-applet, but without luck. The package is not found.
Do I maybe miss some dnf repository?
I am also open to alternative network manager applets, if this is easier. I just need one that will appear in my i3 bar and do the good-old basic stuff. Not searching for something fancy here.
Thanks :slight_smile:
In the OM repos, network manager is networkmanager and the applet is networkmanager-applet. Doing a simple dnf search network will pull up quite a few results, and you can look through to see how we have it named. Just a heads up, dnf search should become one of your best friends when finding packages that you’re familiar with from other distros :+1:
Thank you so much @schappellshow, it worked perfectly.
As you might have guessed, I am new to dnf so I did not know that.
Have a nice day, everyone! :slight_smile:
