how can I install compiz, fusion-icon, ccsm, emerald in my OpenMandriva LX 3.0?
with regards
Ch. Hanisch
with regards
Ch. Hanisch
These are quite old packages. I do not know if they work correctly, but it is worth checking.
Instead of installing each package separately, install the meta packege.
as root - su or sudo
urpmi task-compiz-stable
it will install compiz0.8, ccsm0.8, compiz-fusion, compiz-fusion-plugins-main, compiz-fusion-plugins-extra, emerald, emerald-themes, fusion-icon|
@Hanisch did you try @AngryPenguin’s suggestion?
