and it will open from sddm login screen as any other desktop. Don’t know if this is the best way, if there are improvements/enhancements/betterway let me know.
Edit: Had to force install of ‘libwnck3-3.14.0-1-omv2015.0.x86_64’.
I’m trying to update MATE to version 1.18. Now many big problems are (quite) completrly solved (except for breeze-icons which will solved with version 5.41.0, the same as in cooker).
Testers may use packages in my own repo by using the following commands (warning: test it only in a dedicate vbox or you’ll break your system):
