Thanks.
I tryed from the live and I suceeded to open just a failsafe session with
Exec=/usr/bin/cinnamon-session2d
TryExec=/usr/bin/cinnamon-session2d
Not a big result!
Yes I got lots of failsafe session while trying whatsoever command
When not big crashes, where I had to go with mc from emergency consoleā¦
(grub recovery mode I mean
I got also a kernel warning in journalctl -b. It really seems a bug.
Moved topic to Support
And bug 1841 about xfce is unattended.
Postedit:
Bug 1841 is now fixed.
urpmi task-xfce
Lx 3.0 is the past
Yeah, guess wandboards and arm are more important.
Some dependencies are missing:
sudo urpmi lib64cjs-gir1.0 lib64xfixies-gir4.0 lib64gnomekbd-gir3.0 libgnomekbd-common gksu python2-imaging python2-pexpect
Then type the following command in fail-safe terminal
cinnamon --replace &
Not all is working so other dependencies are missing ā¦
urpmi lib64cjs-gir1.0 lib64xfixies-git4.0 lib64gnomekbd-gir3.0 libgnomekbd-common gksu python-pil python2-imaging python2-io python2-pexpect --test
No package named lib64xfixies-git4.0
No package named python-pil
No package named python2-io
Which repo do you have enabled please?
Iām sorry, I did some error in reporting packages name (I took them from the history so I reported some failed attempt). I corrected the above and I report here again:
Also note libgnomekbd-common is a x86_64 library even fi it is called as a i686 one.
I have the feeling that should be lib64xfixes-gir4.0 right?
- [ruru@omlx-946 ~]$ rpm -qa|grep libgnomekbd-common
libgnomekbd-common-3.6.0-10-omv2015.0.x86_64
Itās so, of course
Today there is an ester egg into my keyboard
System Info does not work here
(does nothing - like many others)
There is no cinnamon entry in sddm, like beforeā¦
cinnamon --replace & is the only way to launch cinnamon then?
Filed a bug report
https://issues.openmandriva.org/show_bug.cgi?id=2102
Try to get a look at ~/.xsession-errors, maybe there are some pother missing packages
Itās the only one I have found until now. I think it has not been well configured or still missing.
About the SDDM entry you the file /usr/share/xsessions/cinnamon.desktop should be enough. If I remember well I wrote it by hand. However Iām testing LightDM and it can see both Cinnamon and MATE. I donāt know if Cinnamon has its own DM.
Here things requiring high privileges canāt start from menu. I opened mcc form terminal. Maybe some services is not properly started (keyring? dbus? other?)
I have no .xsession-errors file in my home ![]()
. .config .gtkrc-2.0-kde .recently-used
.. .dbus .gtkrc-2.0-kde4 Templates
.bash_completion Desktop .hplip .thumbnails
.bash_history Documents .kde4 .vboxclient-clipboard.pid
.bash_logout Downloads .local .vboxclient-display.pid
.bash_profile .esd_auth .mozilla .vboxclient-draganddrop.pid
.bashrc .face.icon Music .vboxclient-seamless.pid
.cache .fonts.conf .oma-welcome Videos
.cinnamon .gksu.lock Pictures .Xauthority
.compose-cache .gnupg .pki .xscreensaver
[ruru@omlx-946 ~]$
FWIW the console where is running cinnamon reads:
Warning: couldn't find charset data for locale en_US; using ISO 8859-1.
[ruru@omlx-946 ~]$ cinnamon --replace &
[1] 5940
[ruru@omlx-946 ~]$ Window manager warning: Software rendering detected: Gallium 0.4 on llvmpipe (LLVM 3.9, 256 bits)
Window manager warning: Failed to load theme "Adwaita": Failed to find a valid file for theme Adwaita
Window manager warning: Could not find theme Adwaita. Falling back to default theme.Cjs-Message: JS LOG: About to start Cinnamon
Cjs-Message: JS LOG: ACTIVATING SOFTWARE RENDERING
St-Message: cogl npot texture sizes SUPPORTED
Cjs-Message: JS LOG: Cinnamon started at Mon Apr 17 2017 11:34:10 GMT-0400 (EDT)
Cjs-Message: JS LOG: network applet: Cannot find connection for active (or connection cannot be read)
openGL version 2.1 Mesa 17 detected (GL Cogl Driver)
MetaSyncRing disabled: couldn't find required GL extensions, or the minimum safe openGL version was not met
Cjs-Message: JS LOG: Invalid network device type, is 14
Cjs-Message: JS LOG: network applet: Found connection for active
(cinnamon:5940): Cjs-WARNING **: JS ERROR: TypeError: this._activeContainer is null
MyApplet.prototype._onMenuKeyPress@/usr/share/cinnamon/applets/menu@cinnamon.org/applet.js:1473
Window manager warning: Invalid WM_TRANSIENT_FOR window 0x1400007 specified for 0x14000bc (Preference).
I really donāt know if there is something useful there.
You may try to launch cinnamon-settings from cli.
