Credits: @zeroability here
Many thanks to the Trinity Desktop Environment project for adding OpenMandriva Lx into their official packaging project:
https://mirror.git.trinitydesktop.org/gitea/TDE/tde-packaging/issues/303
Enabling the repos will require manually creating a .repo
file that will exist in /etc/yum.repos.d
. For this, you can create a file such as trinity.repo
with the following contents:
[TDE-x86_64]
name="Trinity Desktop Environment - x86_64"
baseurl=https://mirror.ppa.trinitydesktop.org/trinity/rpm/omvcooker/trinity-r14/RPMS/x86_64/
gpgcheck=1
gpgkey=https://mirror.ppa.trinitydesktop.org/trinity/rpm/omvcooker/RPM-GPG-KEY-trinity
#type=rpm-md
enabled=1
[TDE-noarch]
name="Trinity Desktop Environment - noarch"
baseurl=https://mirror.ppa.trinitydesktop.org/trinity/rpm/omvcooker/trinity-r14/RPMS/noarch/
gpgcheck=1
#type=rpm-md
enabled=1
This file would be suitable for testing in Cooker (which is probably preferred at this time), and probably ROME.
There isn’t an aarch64
package set at this time, but successful testing may put us in a position to build the specs on ABF.
Rock users can also test it by replacing the following instances:
With:
https://mirror.ppa.trinitydesktop.org/trinity/rpm/omv6
Verify that the repo file is correct by the command dnf repolist
. It should show up in the list of enabled repos. Get started with just the base system with sudo dnf in trinity-tdebase
You can report issues upstream on their Gitea:
They have separate repos that pertain to the components in TDE and your best bet is to open issues for the components.
One of the current issues produces a lot of pop-ups when the session is first logged into:
https://mirror.git.trinitydesktop.org/gitea/TDE/tdebase/issues/556
You have to click Ok
through all the pop-ups and the desktop will load.
Please be respectful, and make a good impression on them.
