Hello, I want to enable and configure Selinux in OpenMandriva Rock 6 Slim. It’s disabled by default. The default package is lib64selinux.x86_64. I tried using chatgpt, but it says it’s disabled. Can you help me? Regarding apparmor, it’s an optional package and it conflicts with another package. I don’t remember which package it is or what it says. I’ll add what folder is behind the apparmor.d in /etc. Why is it there if apparmor isn’t installed and isn’t in the main repo?
It says what is disabled?
You will have a better chance of getting AppArmor working than trying to compile and configure SELinux from source. I am fairly certain we will not be packaging it. To get AppArmor working, we will need the error.
Please follow this. We require outputs to be in English:
Why did you mark my request to provide the information we need in the format we need it in as a Solution, and then delete your post?
