2022-08-30T22:00:00Z
This is where everything started from
How-to downgrade ROME TP to true ROME rolling release in few simple steps
Open Software Repository Selector;
Disable any additional repository;
Switch ‘Update Channel’ from Cooker to Rolling
A warning popup will appear.Click Yes and confirm OK
Clean and refresh repo list;
Make sure you have rolling repository only enabled
Upgrade the system with distro-sync command
At the end of the script, a couple of questions to answer.
Notice ‘Y’ as answer to both, versus the default ‘N’ proposed
Reboot
Opss… ![]()
Just in case, let’s fix it
Better ![]()
Now you may want to enable again the additional repositories.
Clean and refresh repo list and repeat distro-sync to update all the rest.
