Grub2 script errors during upgrade
yep clean all and then update appears to have worked.
I got 2 possible gremlins…one for grub2 scriplet failing and the other maybe missing packages relating to network
but I have rebooted OK
and I have ethernet OK
thanks for reading
snip
Transaction Summary
Install   1 Package
Upgrade  27 Packages
snip
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
snip
Upgrading        : grub2-efi-2.04-3.znver1        16/55
  Upgrading        : grub2-2.04-3.znver1        17/55
  Running scriptlet: grub2-2.04-3.znver1        17/55
Updating /boot/grub2/locale..
Generating grub configuration file ...
Found theme: /boot/grub2/themes/OpenMandriva/theme.txt
Found background: /boot/grub2/themes/OpenMandriva/terminal_background.png
warning: %triggerin(grub2-2.04-3.znver1) scriptlet failed, exit status 1
Error in <unknown> scriptlet in rpm package grub2
snip
dracut: dracut module 'ifcfg' depends on 'network', which can't be installed
dracut: dracut module 'cifs' depends on 'network', which can't be installed
dracut: dracut module 'nfs' depends on 'network', which can't be installed
snip
Running scriptlet: grub2-2.04-2.znver1
snip
snip
Upgraded:
  cpupower-5.5.2-1.znver1                      cryptsetup-2.3.0-1.znver1                    grub2-2.04-3.znver1
  grub2-efi-2.04-3.znver1                      kpmcore-4.0.1-2.znver1                       lib64EGL_mesa0-19.3.4-1.znver1
  lib64GLX_mesa0-19.3.4-1.znver1               lib64cryptsetup12-2.3.0-1.znver1             lib64dri-drivers-19.3.4-1.znver1
  lib64dri-drivers-intel-19.3.4-1.znver1       lib64dri-drivers-nouveau-19.3.4-1.znver1     lib64dri-drivers-radeon-19.3.4-1.znver1
  lib64dri-drivers-swrast-19.3.4-1.znver1      lib64dri-drivers-virtio-19.3.4-1.znver1      lib64dri-drivers-vmwgfx-19.3.4-1.znver1
  lib64gbm1-19.3.4-1.znver1                    lib64glapi0-19.3.4-1.znver1                  lib64kpmcore8-4.0.1-2.znver1
  lib64vdpau-driver-nouveau-19.3.4-1.znver1    lib64vdpau-driver-r300-19.3.4-1.znver1       lib64vdpau-driver-r600-19.3.4-1.znver1
  lib64vdpau-driver-radeonsi-19.3.4-1.znver1   lib64vdpau-driver-softpipe-19.3.4-1.znver1   lib64vdpau-drivers-19.3.4-1.znver1
  lib64xatracker2-19.3.4-1.znver1              oma-welcome-2.1.23-1.noarch                  x86_energy_perf_policy-5.5.2-1.znver1
Installed:
  kernel-release-desktop-5.5.2-1.znver1
Complete!
To address the issues:
Those are warning produced by dracut command and you will see them every time dracut runs. dracut will run every time a kernel is installed. They don’t mean anything and are left over from past, those modules would only be used on really ancient computers.
Developers have been asked if they could please remove those warnings but so far they haven’t. No idea why they don’t remove those. But we keep having to explain this over and over.
Now to next part where
What you posted does not show any boot-able entry created by grub2 but I see you snipped the output:
snip
snip
The part after that second snip is where we could see if the script actually did what it should or failed. So if you could run this command which will run that script again and post all the output here we could perhaps get this sorted:
$ sudo update-grub2
@aus9 an example of output from command ‘sudo update-grub2’ on Rock x86_64 system with 3 different kernels installed.
So to explain: For each kernel you have installed you should see 2 lines of code like this:
Found linux image: /boot/vmlinuz-5.5.2-desktop-1omv4001
Found initrd image: /boot/initrd-5.5.2-desktop-1omv4001.img
These lines you would only see on a multi-boot system and they are entries for other operating systems on other partitions:
Found OpenMandriva Lx 4.2 (4.2) on /dev/nvme0n1p5
Found OpenMandriva Lx 4.2 (4.2) on /dev/nvme0n1p7
Found OpenMandriva Lx 4.2 (4.2) on /dev/nvme0n1p9
Hoping this is helpful for you and other users. Please let us know what you find on your system and if there is a problem it should be fairly easy to get corrected. Sometimes when a kernel is installed there is a script failure and normally it is corrected by either reinstalling the kernel package or re-running dracut and update-grub2 commands.
Post-edit-FWIW: The command to see what kernel you a using is uname -a. For an updated Rock system likely you would see:
$ uname -a
Linux ben-Lx41-64 5.5.2-desktop-1omv4001 #1 SMP Mon Feb 10 17:03:42 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
as requested…
sudo update-grub2
[sudo] password for gordon:
[gordon@box ~]$ uname -a
Linux box 5.5.0-desktop-1omv4001 #1 SMP Mon Jan 27 23:20:31 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
I noticed that your screenshot appears to detect different kernels
while my output shows no detected kernels.
I repeat I have rebooted OK…so I am not fussed by this.
I did want to bring it to someone’s attention in case it was important.
EDIT
FWIW my booting grub2.cfg has this entry
### BEGIN /etc/grub.d/10_linux ###
menuentry 'OpenMandriva Lx' --class openmandriva --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-3161620e-e3db-4520
-90a8-be6eed746cfc' {
        savedefault
        load_video
        set gfxpayload=keep
        insmod gzio
        insmod part_msdos
        insmod ext2
        set root='hd0,msdos1'
        if [ x$feature_platform_search_hint = xy ]; then
          search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos1 --hint-efi=hd0,msdos1 --hint-baremetal=ahci0,msdos1  3161620e-e3db-4520-9
0a8-be6eed746cfc
        else
          search --no-floppy --fs-uuid --set=root 3161620e-e3db-4520-90a8-be6eed746cfc
        fi
        echo    'Loading Linux 5.5.0-desktop-1omv4001 ...'
        linux   /boot/vmlinuz-5.5.0-desktop-1omv4001 root=UUID=3161620e-e3db-4520-90a8-be6eed746cfc ro  quiet splash resume=UUID=0456b0ee-6be6-435
6-8dc1-386ee06e1528 logo.nologo acpi_osi=Linux acpi_osi='!Windows 2012' acpi_backlight=vendor audit=0 rd.timeout=120 scsi_mod.use_blk_mq=1 dm_mod.use_blk_mq=1 rd.systemd.show_status=0 systemd.show_status=0
        echo    'Loading initial ramdisk ...'
        initrd  /boot/initrd-5.5.0-desktop-1omv4001.img
You are correct in that if everything is working no need to get fussed. When you get some time could you please post output of this command:
$ ls -lh /boot
That just lists what in in /boot directory so I can see if anything is missing.
Sometimes simply removing and reinstalling the kernel package will resolve this. To do that:
$ sudo dnf remove kernel-release-desktop-5.5.2-1.znver1
$ sudo dnf install kernel-release-desktop-5.5.2-1.znver1
I decided to do this first. And IMHO I have now decided to get fussy!
reason is your first command now done as my second command shows
ls -lh /boot
total 127M
-rw-r--r-- 1 root root 223K Jan 28 07:28 config-5.5.0-desktop-1omv4001
-rw-r--r-- 1 root root 223K Feb 11 01:18 config-5.5.2-desktop-1omv4001
drwxr-xr-x 3 root root 4.0K Feb  2 02:13 efi
-rw-r--r-- 1 root root 181K Apr 30  2019 elf-memtest86+
drwxr-xr-x 6 root root 4.0K Mar 15 11:58 grub2
-rw------- 1 root root  51M Mar 12 16:21 initrd-5.5.0-desktop-1omv4001.img
-rw------- 1 root root  48M Mar 15 11:58 initrd-5.5.2-desktop-1omv4001.img
-rw-r--r-- 1 root root 179K Apr 30  2019 memtest.bin
-rw-r--r-- 1 root root 3.0M Nov 28 11:40 microcode.img
-rw-r--r-- 1 root root 331K Jan 28 07:28 symvers-5.5.0-desktop-1omv4001.zst
-rw-r--r-- 1 root root 331K Feb 11 01:18 symvers-5.5.2-desktop-1omv4001.zst
-rw-r--r-- 1 root root 4.4M Jan 28 07:28 System.map-5.5.0-desktop-1omv4001
-rw-r--r-- 1 root root 4.4M Feb 11 01:18 System.map-5.5.2-desktop-1omv4001
-rw-r--r-- 1 root root 7.6M Jan 28 07:28 vmlinuz-5.5.0-desktop-1omv4001
-rw-r--r-- 1 root root 7.6M Feb 11 01:18 vmlinuz-5.5.2-desktop-1omv4001
but the second kernel is not getting into my grub.cfg.
so then I did another update-grub2 with root powers and got this
sudo update-grub2
so then I search for 5.5.2 get no hits for the following command
true|cat /boot/grub2/grub.cfg | grep 5.5.2
but if I change it to search if true for hits of 5.5.0 I get heaps.
this time a screen shot as it shows up better IMHO
I have reversed the order so you can see no hits for 5.5.2 at bottom of konsole.
https://imgur.com/g9oqPrQ
Thanks for reading
Therefore…for what ever reason…do you wish me to make a bug report?
Something is definitely wrong. First post output ot this:
$ dnf repolist
Post-edit: Forgot this part: Then if that looks OK then yes we would like to get a bug report on this.
Hi
as requested with a bonus reply :wink:
grub 2 now has successfully updated me thinks
dnf repolist
repo id                                        repo name
rock-testing-znver1                            OpenMandriva Rock - znver1 - Testing
rock-testing-znver1-debuginfo                  OpenMandriva Rock - znver1 - Testing - Debug
rock-testing-znver1-non-free                   OpenMandriva Rock - Non-free - znver1 - Testing
rock-testing-znver1-non-free-debuginfo         OpenMandriva Rock - Non-free - znver1 - Testing - Debug
rock-testing-znver1-restricted                 OpenMandriva Rock - Restricted - znver1 - Testing
rock-testing-znver1-restricted-debuginfo       OpenMandriva Rock - Restricted - znver1 - Testing - Debug
rock-testing-znver1-unsupported                OpenMandriva Rock - Unsupported - znver1 - Testing
rock-testing-znver1-unsupported-debuginfo      OpenMandriva Rock - Unsupported - znver1 - Testing - Debug
rock-updates-znver1                            OpenMandriva Rock - znver1 - Updates
rock-updates-znver1-debuginfo                  OpenMandriva Rock - znver1 - Updates - Debug
rock-updates-znver1-non-free                   OpenMandriva Rock - Non-free - znver1 - Updates
rock-updates-znver1-non-free-debuginfo         OpenMandriva Rock - Non-free - znver1 - Updates - Debug
rock-updates-znver1-restricted                 OpenMandriva Rock - Restricted - znver1 - Updates
rock-updates-znver1-restricted-debuginfo       OpenMandriva Rock - Restricted - znver1 - Updates - Debug
rock-updates-znver1-unsupported                OpenMandriva Rock - Unsupported - znver1 - Updates
rock-updates-znver1-unsupported-debuginfo      OpenMandriva Rock - Unsupported - znver1 - Updates - Debug
rock-znver1                                    OpenMandriva Rock - znver1
rock-znver1-debuginfo                          OpenMandriva Rock - znver1 - Debug
rock-znver1-non-free                           OpenMandriva Rock - Non-free - znver1
rock-znver1-non-free-debuginfo                 OpenMandriva Rock - Non-free - znver1 - Debug
rock-znver1-restricted                         OpenMandriva Rock - Restricted - znver1
rock-znver1-restricted-debuginfo               OpenMandriva Rock - Restricted - znver1 - Debug
rock-znver1-unsupported                        OpenMandriva Rock - Unsupported - znver1
rock-znver1-unsupported-debuginfo              OpenMandriva Rock - Unsupported - znver1 - Debug
[gordon@box ~]$
grub2 stuff
 sudo dnf clean all
 105 files removed
 [gordon@box ~]$ sudo dnf update
 OpenMandriva Rock - znver1                                                     924 kB/s |  12 MB     00:13
 OpenMandriva Rock - znver1 - Updates                                            50 kB/s |  95 kB     00:01
 OpenMandriva Rock - znver1 - Debug                                             820 kB/s | 4.9 MB     00:06
 OpenMandriva Rock - znver1 - Updates - Debug                                    20 kB/s |  32 kB     00:01
 OpenMandriva Rock - znver1 - Testing - Debug                                    28 kB/s |  53 kB     00:01
 OpenMandriva Rock - Unsupported - znver1 - Debug                               365 kB/s | 1.7 MB     00:04
 OpenMandriva Rock - Unsupported - znver1 - Updates - Debug                     3.4 kB/s | 4.3 kB     00:01
 OpenMandriva Rock - Unsupported - znver1 - Testing - Debug                     4.6 kB/s | 5.8 kB     00:01
 OpenMandriva Rock - Restricted - znver1 - Debug                                 28 kB/s |  45 kB     00:01
 OpenMandriva Rock - Restricted - znver1 - Updates - Debug                      275  B/s | 344  B     00:01
 OpenMandriva Rock - Restricted - znver1 - Testing - Debug                       99  B/s | 153  B     00:01
Errors during downloading metadata for repository 'rock-testing-znver1-restricted-debuginfo':
 - Status code: 404 for http://abf-downloads.openmandriva.org//rock/repository/znver1/debug_restricted/testing/repodata/repomd.xml (IP: 185.184.176.69)
Error: Failed to download metadata for repo 'rock-testing-znver1-restricted-debuginfo': Cannot download repomd.xml: Cannot download repodata/repomd.xml: All mirrors were tried
OpenMandriva Rock - Non-free - znver1 - Debug                                  6.1 kB/s | 7.7 kB     00:01
OpenMandriva Rock - Non-free - znver1 - Updates - Debug                        275  B/s | 344  B     00:01
OpenMandriva Rock - Non-free - znver1 - Testing - Debug                         99  B/s | 153  B     00:01
Errors during downloading metadata for repository 'rock-testing-znver1-non-free-debuginfo':
  - Status code: 404 for http://abf-downloads.openmandriva.org//rock/repository/znver1/debug_non-free/testing/repodata/repomd.xml (IP: 185.184.176.69)
Error: Failed to download metadata for repo 'rock-testing-znver1-non-free-debuginfo': Cannot download repomd.xml: Cannot download repodata/repomd.xml: All mirrors were tried
Ignoring repositories: rock-testing-znver1-restricted-debuginfo, rock-testing-znver1-non-free-debuginfo
 Dependencies resolved.
 Package                  Architecture          Version               Repository                          Size
Upgrading:
 grub2                    znver1                2.04-4                rock-updates-znver1                3.6 M
 grub2-efi                znver1                2.04-4                rock-updates-znver1                822 k
Transaction Summary
 Upgrade  2 Packages
Total download size: 4.4 M
Is this ok [y/N]: y
Downloading Packages:
(1/2): grub2-efi-2.04-4-omv4001.znver1.rpm                                     299 kB/s | 822 kB     00:02
(2/2): grub2-2.04-4-omv4001.znver1.rpm                                         1.0 MB/s | 3.6 MB     00:03
Total        1.3 MB/s | 4.4 MB     00:03
Running transaction
 Preparing        :        1/1
 Upgrading        : grub2-efi-2.04-4.znver1                                                               1/4
 Upgrading        : grub2-2.04-4.znver1        2/4
  Running scriptlet: grub2-2.04-4.znver1        2/4
 Found linux image: /boot/vmlinuz-5.5.0-desktop-1omv4001
 Found initrd image: /boot/initrd-5.5.0-desktop-1omv4001.img
 Found memtest image: /boot/elf-memtest86+
 Found Windows 10 on /dev/sdb1
 done
  Running scriptlet: grub2-2.04-3.znver1        3/4
 Cleanup          : grub2-2.04-3.znver1        3/4
  Cleanup          : grub2-efi-2.04-3.znver1                                                               4/4
  Running scriptlet: grub2-efi-2.04-3.znver1                                                               4/4
 done
 done
   Verifying        : grub2-2.04-4.znver1        1/4
   Verifying        : grub2-2.04-3.znver1        2/4
   Verifying        : grub2-efi-2.04-4.znver1                                                               3/4
  Verifying        : grub2-efi-2.04-3.znver1                                                               4/4
 Upgraded:
  grub2-2.04-4.znver1                                  grub2-efi-2.04-4.znver1
 Complete!
you may notice there are still some repo errors.
but…
now gives me all the hits I desire.
I think we can now mark this as solved. Just a gremlin when there was a failed update IMHO.
Yes that update where grub2 script runs now shows you with normal looking out put for both kernels so you should have boot entries for both in /boot/grub2/grub.cfg and you should be able to boot to both kernels. So this problem is fixed.
Note about your repositories. Normally people just use the main, unsupported, restricted, non-free and the update repos for those 4. All that debug stuff is for developers and is not hardly used in Rock/Lx 4.1. My Rock systems all look like this screen shot:
Also so you and other users know the restricted repos that return 404 Cannot download error don’t have any packages in them. So they are empty and dnf does not have a metadata file to find so it will list those as 404 Cannot download. No worries for those.
@aus9 in view of some of the weird things we have seen with your system you could try to disable all the debug repos and leave only the ones in my screen shot enabled and then do this to maybe straighten out your system (hopefully):
$ sudo dnf clean all && sudo dnf --best --allowerasing distro-sync
hi
Before I post my output…for my own selfish benefit I looked at the timestamps for files under /etc/yum.d
all are older dates of Mar 13…my install date except this one
-rw-r–r-- 1 root root 10080 Mar 15 13:52 openmandriva-rock-znver1.repo
Is that the correct file to have been adjusted?
IMHO there is still something going on if true. I can upload my contents to a file sharing site if you like but
first here is my command output
60 files removed
OpenMandriva Rock - znver1        1.6 MB/s |  12 MB     00:07
OpenMandriva Rock - znver1 - Debug                                                            774 kB/s | 4.9 MB     00:06
OpenMandriva Rock - Unsupported - znver1 - Debug                                              503 kB/s | 1.7 MB     00:03
OpenMandriva Rock - Restricted - znver1 - Updates - Debug                                     269  B/s | 344  B     00:01
OpenMandriva Rock - Non-free - znver1 - Debug                                                 6.2 kB/s | 7.7 kB     00:01
OpenMandriva Rock - Non-free - znver1 - Updates - Debug                                       264  B/s | 344  B     00:01
Nothing to do.
Complete!
as you can see rock-testing-znver1-restricted-debuginfo, rock-testing-znver1-non-free-debuginfo are allegedly disabled?
and so should show enabled=0 in the file I named?
but snippets show
[rock-znver1-restricted-debuginfo]
name=“OpenMandriva Rock - Restricted - znver1 - Debug”
…enabled=1
[rock-updates-znver1-restricted-debuginfo]
name=“OpenMandriva Rock - Restricted - znver1 - Updates - Debug”
…enabled=1
[rock-testing-znver1-restricted-debuginfo]
name=“OpenMandriva Rock - Restricted - znver1 - Testing - Debug”
Look I think you get the idea. …Maybe I should grab the file off the usb install media and see if that is the same…or does it suggest
somehow I inherited a dev’s configs?
cheers
First point:
What I said was:
Meaning that first you disable all the unnecessary (and possible problem causing) debug repositories and then run that command. Simply running the command won’t change anything.
Second point:
Very important question: So where did you get the ISO file you are using?
Normally when you install OM Lx 4.1/Rock you would have only 2 repositories enabled (and only 2). This is very well and strongly established protocol by our developers. When you first boot into a freshly installed system by default you should have these and only these enabled:
$ dnf repolist
repo id        repo name
If your install media shows any repos enabled beyond those 2 then do not use that install media. Something is really wrong. If immediately after you install OM Lx 4.1 you have any repos enabled besides those 2 something is very wrong.
Third point:
If a user does want maximum availability of software then they could able only the additional repos shown in screen shot in this post. (An exception is that gamers and some other users needing to install 3rd party software may need to also enable a few i686 repos.)
Post-edit: Yes I acknowledge that the situation with repositories in OpenMandriva is confusing to users. However it is of utmost importance that users understand what they are doing and do things in the correct way or there will be issues. Improperly configured repositories left alone for to long will lead to issues that can practically only be resolved by a fresh installation.
Apologies if the above post sounds to much like me ranting. As a QA person with OM the idea that there might be an ISO out there with all those repos enabled and worse that such an ISO might be accessible to users scares me.
I have no problem with people with passion so do not consider it a rant.
However, I had other matters to consider so have now put a different distro on my hd
I can not see how to close my account but will no longer reply.
cheers
Closing thread then.
