While I do use OM on my desktop, I have an Arch-based Hyprland install on another laptop. Started with end-4’s dotfiles, and changed a ton of stuff. Quite satisfying to use and see. Hyprland is quite nice. The bar changes color scheme based on what wallpaper you’re using. Hopefully it’s okay to throw this out here.
That looks really nice.
Dood, what bar is that? That looks nice!
It’s actually a custom AGS bar. There are two side panels that slide out. Quite a few dependencies. But if you just wanted the bar I can try to send over the configs
Since it’s an arch install, not sure how difficult it’d be to port over all the packages needed to OM. It’d be so painful to figure all of them out ![]()
Send them! I’ll play with it.
That’s the entire ags folder in .config.
Holler if it seems like something is missing and I’ll try to find it for you.
Thank you!
