Frozen Black Screen with Dual Monitor and Nvidia drivers
Hello, I’m trying to get OMLx to stop giving a frozen black screen with dual monitors before login. I had to unplug the second monitor, reach the desktop before I could plug it back in to avoid the issue. Another problem is OM-welcome doesn’t work and crashes at startup. When I’ve looked at the wiki, I found it difficult to use, search, or seemingly incomplete. It also doesn’t help now because, at the time of writing this, the wiki requires some sort of host login. No matter what device I’m on. I’ve tried to stick to the forum as much as possible. There have been a few commands I’ve tried, one of which included a lib64nvidia-egl-wayland1 package. Whether it was that package or one of its dependencies, it caused the black screen problem to be worse. Om-welcome would open finally but, within a few minutes the desktop would crash to a black screen with a cursor. I realized that and removed it while in console mode. I don’t know what to do at this point.
list of commands I tried.txt (17.8 KB)
Operating System: OpenMandriva Lx 6.0
GRUB Dual Boot with Win10 (separate drives)
KDE Plasma Version: 6.3.4
Qt Version: 6.9.0
Kernel Version: 6.14.2-desktop-3omv2590 (64-bit)
Graphics Platform: X11
Processors: 16 × AMD Ryzen 7 5800X 8-Core Processor
Memory: 31.3 GiB of RAM
Graphics Processor: NVIDIA GeForce RTX 3080 Lite Hash Rate [Discrete]
Manufacturer: ASUS ROG Strix 3080 10GB GDDR6X
Dual Gigabyte G27QC A 1440p 165 Hz 27” Monitors
Did you do these things?
Seems like not. Here is the second hit from searching for “black screen” in the search bar created when you click on the magnifying lens icon in the top right hand corner of the forum:
