[root@OpenMandriva3Lx dev]# inxi -F -c 0
System: Host: OpenMandriva3Lx Kernel: 4.6.5-desktop-2omv x86_64 (64 bit)
Desktop: KDE Plasma 5.6.5
Distro: OpenMandrivaLinux 3.0 Einsteinium
Machine: Mobo: ASUSTeK model: P5K-E v: Rev 1.xx serial: MS6C7AB16204480
Bios: American Megatrends v: 1305 date: 06/19/2009
CPU: Quad core Intel Core2 Quad Q6600 (-MCP-) cache: 4096 KB
clock speeds: max: 2394 MHz 1: 2394 MHz 2: 1596 MHz
3: 1596 MHz 4: 1596 MHz
Graphics: Card: NVIDIA G86 [Quadro NVS 290]
Display Server: X.org 1.18.4 driver: N/A
tty size: 69x38 Advanced Data: N/A for root
Audio: Card Intel 82801I (ICH9 Family) HD Audio Controller
driver: snd_hda_intel
Sound: ALSA v: k4.6.5-desktop-2omv
Network: Card-1: Marvell 88E8056 PCI-E Gigabit Ethernet Controller
driver: sky2
IF: enp2s0 state: up speed: 1000 Mbps duplex: full
mac: 00:dd:60:c7:03:b7
Card-2: Realtek RTL8187 Wireless Adapter
IF: N/A state: N/A mac: N/A
Drives: HDD Total Size: 832.2GB (50.3% used)
ID-1: /dev/sda model: PLEXTOR_PX size: 512.1GB
ID-2: /dev/sdb model: WDC_WD3200AAJS size: 320.1GB
ID-1: / size: 12G used: 5.9G (55%) fs: ext4 dev: /dev/sdb15
RAID: No RAID devices: /proc/mdstat, md_mod kernel module present
Sensors: System Temperatures: cpu: 54.0C mobo: 42.0C gpu: 67.0
Fan Speeds (in rpm): cpu: 1748 sys-1: 1278 sys-2: 4963 sys-3: 1360
Info: Processes: 334 Uptime: 19 min Memory: 1530.9/7986.5MB
Client: Shell (bash) inxi: 2.2.27
When I use the GUI to update OMA (after fresh installation from USB), I first get 30 updates offered. Installing them goes just fine. BUT then 1583 updates are found but the GUI is unable to show the packages - it just keeps loading and loading and loading (I kept it running for almost a day but nothing happens though I can see in top CPU kernels are being used…).
When I go the urpmi route, it fails after a while due to dependency problems (KDE & lib6). I know there are a few posts about a recent bug which is being solved.
Is there a central topic that I can follow so I can test once more to update OMA once that latest build bug is solved?
I’d love to hear how and when I can update OMA with the GUI as it should (for a fresh system). If somehow somewhere could be a central topic so new OMA users know what’s up and when it’s safe to update OMA (currently I’m at my 4th installation in 2 weeks, often ending up with a corrupt desktop manager or even no windows manager, all trying to solve the dependency problems through urpmi…)
Peace!
Devnullius
