Fix for sof-firmware on HP EliteBook 850 G6 HDMI audio no longer work
I have upgraded my Linux by https://forum.openmandriva.org/t/upgrading-om-lx-4-2-system-to-om-lx-4-3/4338
Everything went smoothly.
[mila@mila-hpelitebook850g6 etc]$ cat lsb-release
LSB_VERSION=
DISTRIB_ID=OpenMandrivaLinux
DISTRIB_RELEASE=4.3
DISTRIB_CODENAME=Dysprosium
DISTRIB_DESCRIPTION="OpenMandriva Lx 4.3"
[mila@mila-hpelitebook850g6 etc]$ uname -a
Linux mila-hpelitebook850g6 5.16.13-desktop-1omv4003 #1 SMP PREEMPT Wed Mar 9 19:33:24 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
But the problem was with HDMI audio.
I have tried both pipewire-pulse and pulseaudio-server.
When I tried pulseaudio-server I did not see any HOMI profile to choose.
When I tried pipewire-pulse I did not see any HOMI profile to choose but I could choose Pro Audio with 3 -5.
I could switch to Pro Audio 3 and I saw that it works but without any sound.
The main problem was with my old setting from OpenMandriva Lx 4.2
I have install sof driver there. During that time it was a good solution,
See my post OMA 4.2 Sound and microphone on HP EliteBook 850 G6.
But the time has changed.
How have I solved it?
I have upgraded into sof 1.8. https://github.com/thesofproject/sof/releases/tag/v1.8
It did not help me.
I found a solution on these sites.
https://bbs.archlinux.org/viewtopic.php?id=271421
https://github.com/thesofproject/sof/issues/2251
https://bugzilla.kernel.org/show_bug.cgi?id=205959
I have run echo "options snd-intel-dspcfg dsp_driver=1" > /etc/modprobe.d/alsa.conf
Now I use the kernel driver and there are many HDMI profiles to choose.
See https://elixir.bootlin.com/linux/v5.16.13/source/sound/hda/intel-dsp-config.c for possible numbers.
Hi,
Thank You for your post and solution.
I have HP Elitebook X360 1040 G5, Ubuntu 22.10 Kinetic with 5.19.0 kernel.
And I had this problem. No HDMI Audio output available (where there was TV connected).
echo “options snd-intel-dspcfg dsp_driver=1” > /etc/modprobe.d/alsa.conf
(and restart) solved problem. Thank You! :-).
This comment is for other peaple with such issue, for easier solution find.
Welcome @mkdugi to OpenMandriva Community and our forum. If you are interested in trying OpenMandriva you can find latest offerings here.
OpenMandriva is designed to be a Community Linux distribution.
OpenMandriva has no employees. It consists of a small group of all volunteer, unpaid, part-time, developers and other contributors - and we all wish there were more of us.
As a Community distribution of Linux we depend on community members to help solve issues and make things better.
