It would be very nice to flag Firefox so it could run default on wayland instead of xwayland on a wayland session.
That is how it is on OpenSuSE, Fedora, Gentoo, ALTLinux, Rosa Linux…
In order that OM developers see this request it would be best to file bug report. Select New issue>Enhancement request.
Sure! Done thing:). Thanks for the hint !
@yusssufff another thought is that you may need to explain better what you mean? If you are using Plasma desktop you have 2 choices that I know of to start the desktop:
startplasma-waylandstartplasma-x11
If you look in /usr/bin you will see those plus startx which is same a startplasma-x11. There is also a startx-pulseaudio-x11 which I know nothing about but I just asked in OpenMandriva Cooker matrix channel. You are welcome to go there and ask developers questions directly if you wish.
Edit: I think it safe to assume that startx-pulseaudio-x11 does not have anything to do with wayland. Also I am not close to expert on this issue, just another user.
Oh what i mean is that on a wayland session (plasma-wayland or gnome-wayland), some apps are run under xwayland (a sort of xorg-wayland translation layer), and some run natively under wayland.
Typically basic system apps (discover, gnome-software…) are running under wayland in a wayland session.
Firefox is able to run under wayland for a while (Firefox Wayland development in 2021 – Martin Stransky's Blog ), and its smoothier, and has better VAAPI support.
But currently OM’s Firefox is defaulting to xwayland instead.
Can you try on wayland session (gnome-wayland or plasma-wayland, wayfire etc,) this command:
MOZ_ENABLE_WAYLAND=1 firefox
This should launch firefox with pure wayland and not a xwayland
@crisb is a Firefox maintainer. Maybe he can you look at it?
ok, package with Wayland support by default and vaapi compiled for cooker and rolling/testing.
Wonderfull!
Thanks a lot!
