$ sudo urpmi php-mcrypt
(medium "main")
lib64mcrypt4 2.5.8 25 omv 2015.0 x86_64
libmcrypt 2.5.8 25 omv 2015.0 x86_64
php-mcrypt 7.0.9 1 omv 2015.0 x86_64
419KB of additional disk space will be used.
then the command returns:
$ php -m | grep ctype
PHP Warning: PHP Startup: Unable to load dynamic library 'mcrypt.so' (tried: /usr/lib64/php/extensions/mcrypt.so (/usr/lib64/php/extensions/mcrypt.so: undefined symbol: spprintf), /usr/lib64/php/extensions/mcrypt.so.so (/usr/lib64/php/extensions/mcrypt.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
ctype
Post-edit: Which looks exactly like the error you are getting.
At this point I recommend going to #openmandriva-cooker on Freenode IRC and ask your questions there or filing a bug report or maybe better both. There do seem to be a number of bugs reports involving nextcloud and or php already so would be good to get developers working on this now. But this needs reporting by those that actually use nextcloud or other services where php stuff is broken.
This could mean the server administrator is doing maintenance or has orphan php files laying around, please contact the server administrator or come back later. Thank you.
The package php-fpm isn’t loaded on my system, the OpenMandrivaLx3 owncloud and nextcloud packages doesn’t seem to need it.
On the other hand apache-mod_php is loaded and it seems to be needed by owncloud and nextcloud.
Question: Is it possible there is also something wrong with apache-mod_php. By loading it another package is unloaded. As a result I can’t list the installed apache modules any more with:
$ /usr/sbin/apachectl -M
/usr/sbin/apachectl: line 101: /usr/sbin/httpd: No such file or directory
I don’t know what affect this will have on nextcloud and owncloud but our mirrors haven’t updated for over 14 days. That appears to have been fixed this afternoon and update have gotten to http://distro.ibiblio.org and should get to other mirrors over the next 8 or so hours. Using “standard” repos I’m showing (obviously pertains to my own system) these packages to update:
Hello Ben,
Thanks for reactivating the mirror updates. It looks like a large number of php packages, I am using, is updated. Time to start nextcloud testing again. I’ll keep you informed.
When I additionally install the apache-mod_php package:
The apache-mpm-event package is removed from the system.
Only the httpd-prefork daemon is available in MCC.
I have to start the daemons manually.
I get an error when I try to list my installed apache modules as: $ /usr/sbin/apachectl -M /usr/sbin/apachectl: line 101: /usr/sbin/httpd: No such file or directory
