Error Installing Freecad - Rome x86_64 and znver1
  • OpenMandriva Lx version:
  • ROME Plasma6 x86_64
 [michael@MSIA88XM-E45V2 ~]$ sudo dnf --refresh install freecad
OpenMandriva Rolling - x86_64                                      1.3 kB/s | 2.4 kB     00:01
OpenMandriva Rolling - Extra - x86_64                               74 kB/s | 1.4 MB     00:19
OpenMandriva Rolling - Restricted - x86_64                         7.3 kB/s |  25 kB     00:03
OpenMandriva Rolling - Non-free - x86_64                           8.3 kB/s |  29 kB     00:03
Error:
 Problem: package freecad-0.21.2-5.x86_64 from rolling-x86_64-extra requires python3dist(shiboken2), but none of the providers can be installed
  - conflicting requests
  - nothing provides libclang.so.18.1()(64bit) needed by shiboken2-5.15.12-2.x86_64 from rolling-x86_64
  - nothing provides libclang.so.18.1(LLVM_13)(64bit) needed by shiboken2-5.15.12-2.x86_64 from rolling-x86_64
I tried adding ‘–skip-broken’ to skip uninstallable packages, got the same result.
Any thoughts?
Hi guys!
  • Rome 24.09 znver1
  • KDE Wayland 6.0
  • Problem installing Freecad
 [michael@AsusProArtX570CreatorWiFi ~]$ sudo dnf --refresh install freecad
OpenMandriva Rolling - znver1        1.5 kB/s | 2.4 kB     00:01
OpenMandriva Rolling - Extra - znver1                                                              1.5 kB/s | 2.4 kB     00:01
OpenMandriva Rolling - Restricted - znver1                                                         1.5 kB/s | 2.4 kB     00:01
OpenMandriva Rolling - Non-free - znver1                                                           1.4 kB/s | 2.4 kB     00:01
Error:
 Problem: package freecad-0.21.2-5.znver1 from rolling-znver1-extra requires python3dist(shiboken2), but none of the providers can be installed
  - nothing provides libclang.so.18.1()(64bit) needed by shiboken2-5.15.12-2.znver1 from rolling-znver1
  - nothing provides libclang.so.18.1(LLVM_13)(64bit) needed by shiboken2-5.15.12-2.znver1 from rolling-znver1
I tried adding the -skip-broken’ to skip uninstallable packages, got same result.
Any thoughts?
Hi @deltakprime
pyside2 should be rebuild after the update of clang. @ben79 fixed this in cooker so it should be fixed soon in ROME.
Hey mandian & ben79:
Thank you so much…I’ll watch for it!
I really appreciate all your help.
Wishing you both a great day!
Mike
PS:
Where will the rebuild status of clang be initially posted?
Any news re: clang update?
Freecad build fails:
Fail reason b'error: Package check /usr/bin/rpmlint --file /builddir/build/SOURCES/freecad.rpmlintrc /builddir/build/SRPMS/freecad-0.21.2-7.src.rpm failed.' b error: no type named 'mt19937' in namespace 'boost'; did you mean 'std::mt19937'? b error: no member named 'mt19937' in namespace 'boost' b'error: Bad exit status from /var/tmp/rpm-tmp.cfpex7 (%build)'
Will need the attention of developers when they get time.
@bero fixed freecad in Cooker and package is built. It will be in ROME (rolling) next time there is a major update. That should be soon in OM time.
I should also add that I tried building the new “fixed” freecad for ROME (rolling) and it would not build. That means that freecad will need other library or system packages that will come with the next major ROME (rolling) upgrade.
Current stable version: 1.0.0
FreeCAD: Your own 3D parametric modeler
Release notes 1.0 - FreeCAD Documentation
FYI :wink:
Thanks.
Yes we should upgrade to newer version. Sometimes that can take some time depending on the nature of the changes. Let’s hope this time it is just a simple upgrade with little to fix.
Meanwhile the version in Cooker does install and open:
I’ll leave how well it works to people that know what they are doing with this software.
We are working at packaging version 1.0.0 with the new Qt6-based GUI, it will be in cooker repository soon.
Thanks for the attention and the updates.
I’ll be ready to try it again when the new release is out.
Mike
I am trying to builld the new version with qt6 support and push it in into main branch. Most of the dependency packages are ready, but this still requires some days.
You may always follow the build status in real time of any packages at OpenMandriva ABF.
freecad-0.21.2-7 installs in ROME system.
Ben:
Thanks… I successfully installed FreeCad yesterday…
…SFSG!
:sunglasses::+1:
I’ll get a better look at it today.
Later…
Mike
FreeCAD 1.0.0 is in cooker now and will be soon in Rolling too (version 1.0.0-8).
Currently installed v0.21.2, looking forward to v1.0.0!
Thanks!
