Enter key not working in Konsole
Fresh download and install from today.
OpenMandrivaLx.rolling-snapshot.20250615.4008-plasma6x11.x86_64.iso
KDE
pressing enter / return in Konsole does nothing after a fresh install. Which is bad because can’t do anything now.
It’s a VirtualBox installation with macOS as host.
Update 1
I tried to log in with root and worked. Of course I don’t want to use the system as root user all the time.
Update 2
Using root I was able to install zsh I was able to install zsh and that worked. So it’s some kind of bash problem.
Welcome back.
Is this an intel based Mac?
Still Intel. But since the enter key works everywhere else including zshell I suspect a problem with bash. I also haven’t used bash in decades so it might be my configuration as I reinstalled the operating system from scratch but keeps /home on a separate partition.
Quick test: install xguest, logout, enter the guest account and check if things look correct there.
If they are ok then it’s a configs problem in your home.
The problem is this isn’t being widely reported in other configurations on our side. It’s more than likely a VirtualBox issue. Please check their forum for reports, also.
