Earth shaking problem with Lx 4 ISO # 2535!
OK, I exagerated for attention to this post. I am booted in to this ISO doing some QA and found a few little issues. So don’t let the title fool you this is a smallish thing not earth shaking.
One is the Help aka:Khelpcenter is empty. Here’s screen shots.
So one might ask “What’s the problem ben79?” To which I reply if it is going to be empty it maybe should not be in the menu. If it needs to be in the menu then there ought to be some content that actually will help users. Thats what I say.
Post edit: This is related to this thread I’m thinking.
The krfb issue in the above screen shots is not what it looks like, not a problem. It occured because I used the Close X icon on the right of title bar to close krfb and then it won’t reopen because it is still running. You have to close it with the File>Quit thingy.
Does not close:
Does close:
So for purposes of release this is not an issue IMO.
:thinking:
ISO build 2535
Well you can see my screen shots are empty.
So not sure what is going on but I can only report what I see.
Yes, same here :wink:
I’m posting this from ‘Live’ ISO 2535 on hardware:
Empty. Every thing in contents is empty.
Also this is the home page in Falkon, and it does not look so good:
I’m thinking we wanted this instead?
Or maybe there is a reason I don’t know? Again this is posted directly from ‘Live’ ISO 2535 on hardware.
I can confirm in live mode is all empty.
However in this fresh install (vbox virtual machine) I just installed kompare, and updated a couple of packages coming from “dnf upgrade”. All the rest is as default.
lib64kompareinterface5-19.04.2-1.x86_64       Wed 12 Jun 2019 11:44:39 PM CEST
kompare-19.04.2-1.x86_64                      Wed 12 Jun 2019 11:44:39 PM CEST
diffutils-3.7-1.x86_64                        Wed 12 Jun 2019 11:44:39 PM CEST
libkomparediff2-19.04.2-1.x86_64              Wed 12 Jun 2019 11:44:38 PM CEST
lib64komparediff2_5-19.04.2-1.x86_64          Wed 12 Jun 2019 11:44:38 PM CEST
lib64komparedialogpages5-19.04.2-1.x86_64     Wed 12 Jun 2019 11:44:38 PM CEST
quick-usb-formatter-0.6-0.altlinux.2.x86_64   Wed 12 Jun 2019 11:39:57 PM CEST
chkconfig-1.11-3.x86_64                       Wed 12 Jun 2019 11:39:57 PM CEST
gpg-pubkey-bf81de15-51817942                  Wed 12 Jun 2019 11:39:56 PM CEST
Yes maybe missing a redirect to our main site.
Not really missed but wrong.
Fixed Fix startpage · OpenMandrivaAssociation/falkon@5366b5a · GitHub
make first update is useful
@rugyada as far as I am concerned it is OK if help is empty on ISO if that is on purpose. But if that is the case it should be noted in Release Notes. At any rate for QA testing ISO we are supposed to check the ‘Live’ ISO to be sure everything is working (or at least opening) like it is supposed to. That is what I was doing. And pretty much everything is working or at least opening.
@ben79 yes, comparing different experiences for the purpose to understand what may be ‘wrong’ if any or fixable.
