I’m trying to install D-link DWA-182 rev. C1 usb network adapter in OpenMandriva Lx 4.1. The desktop environmet is KDE.
The adapter has a Realtek 8812AU chipset. It is not detected by the OS. Does anyone know a way to install it? Is there a precompiled rpm to it?
I’ve manage to install the dongle by just following the instructions in Github’s gordboy page about rtl8812au module compilation.
I think this topic may be regarded as closed.
General information for all OpenMandriva users. wifi drivers are generally kernel modules these days. You can find what your current kernel has available by opening Konsole and running this command:
$ ls -lh /lib/modules/$(uname -r)/kernel/drivers/net/wireless
And sometimes you do need to “look around” for instance in this case for Realtek the various drivers are in as I recall 4 different sub-directories.
If you don’t see your driver listed then it is time to do internet search for “Linux <My_Wifi_driver>”. And in that case of course you will have to install it yourself as @Renato_A did here.
