Duplicate the panel on Plasma 6?
Does anybody know if it’s possible to duplicate the panel on all monitors? I run 3 and it would be nice to have it on all 3.
I’ve found where I can add a new panel but it looks like it always goes to the primary monitor.
Which panel are you trying to duplicate? If you are talking about the main one, it only pins to one at a time. You can add a Global panel and customize from there if you want a similar experience as the default one. Or, you can edit the panels on all three for different purposes.
You will be able to do that with upcoming Plasma 6.3 (see the 1st notable feature), which is currently in beta and will be released February the 11th.
Thats what I thought. But every panel I add only goes to the primary monitor.
I’ll just wait and see if 6.3 will work.
Either that or run polybar, lol.
See if you can go into Edit Mode and from Panel and Desktop Management, try to move the other panel to the other monitor by Click, Drag, and Drop.
It does not.
But I can drag around the widgets. Took a bit to get it back to looking right again, lol.
Edit
Yes it does. Lol. Im a bonehehead.
