After some web research, it seems it might be a python issue. I know exactly nothing about python so I’m taking the web’s word for it.
I installed Dropbox from the package manager and hit the icon but nothing happened. I then ran it from the command line and got the aforementioned error.
I’ve run the OMV bug report tool and have that should it be necessary. If any further information is needed, please let me know.
Hi @StevenSpears,
it is sad, I know
I use dropbox to work and it must operate.
Please check my reply as “solved” so to help others with the same problem
