Downloading ISO
  • OpenMandriva Lx version:
  • Desktop environment (KDE,):
Hello, I hope this on the right place.
I want to start with openMandriva.
But downloading the right one is a bit of a challenge.
I Have AMD Ryzen possessor and I want Rome (wayland/rolling)
So after clicking thru the website to get the right one I ended up here:
OpenMandrivaLx.rolling-snapshot.20241225.3525-plasma6.znver1.iso
But if I click om the user (creator?) it says " Retired"
And the iso is from December 25, 2024.
So the iso is no langer maintained?, and the next question, what should I chose?
Hi @jsteen and welcome to OM,
I think that it just means he is retiered professionally, Ben is active in the community and i think actively maintains packages for OM but I imagine he will see this post and confirm. You sould be ok to download and install. However I don’t know why there are no rome znver isos on the sourceforge page unless the newer rome kernel has itergrated the zen optimisations? I which case this link maybe better.
openmandriva.rome-24.12-plasma6.wayland.x86_64.iso
Again maybe wait for conformation.
@jsteen
welcome1
I don’t understand what you mean :slight_smile:
Anyway:
ROME plasma6.wayland ryzen
Build 3643 just started. Please wait a few time until it’s finished.
Thanks for clearing this up.
I wil wait some time en then download build nr 3643
If anyone has display problems with the Plasma6 Wayland isos it is easy to install task-plasma6-x11 and switch to X11 at the sddm login screen.
This is more likely to occur if one has nVidia graphics.
