DnfDrake Window Broken
OpenMandriva Lx version: ROME 25.01
Desktop environment (KDE, LXQT…): KDE Plasma 6.2.5
Description of the issue (screenshots if relevant): When opening DnfDrake, it scales out of bounds shown in the screenshot below and cannot be resized forcing app navigation by moving the window.
Relevant informations (hardware involved, software version, logs or output…): DnfDrake 4.2.97
Topic created at @WilsonPhillips’s request
I can verify that it does not respect the taskbar position on my system.
I use Wayland.
Screen 0: minimum 16 x 16, current 2880 x 1800, maximum 32767 x 32767
eDP-1 connected primary 2880x1800+0+0 (normal left inverted right x axis y axis) 312mm x 195mm
   2880x1800    119.96*+
   2048x1536    119.95
   1920x1440    119.97
   1600x1200    119.82
   1440x1080    119.92
   1400x1050    119.90
   1280x1024    119.83
   1280x960     119.89
   1152x864     119.77
   1024x768     119.80
   800x600      119.85
   640x480      119.52
   320x240      117.34
   2560x1600    119.93
   1920x1200    119.90
   1680x1050    119.89
   1440x900     119.94
   1280x800     119.85
   1152x720     119.73
   960x600      119.74
   928x580      119.55
   800x500      119.47
   768x480      119.71
   720x480      119.65
   640x400      119.64
   320x200      117.55
   2880x1620    119.95
   2560x1440    119.95
   2048x1152    119.96
   1920x1080    119.93
   1600x900     119.95
   1368x768     119.83
   1280x720     119.86
   1024x576     119.85
   864x486      119.69
   720x400      119.54
   640x350      119.24
I use X11. The button does make it smaller, but I still cannot manually resize the window. It should not launch out of bounds. It is a work in progress, so I understand.
┌──[wilson@heisenberg] Thu Feb 06, 10:28:45 [~]
└──[ <$> xrandr
Screen 0: minimum 8 x 8, current 2560 x 1080, maximum 32767 x 32767
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected primary 2560x1080+0+0 (normal left inverted right x axis y axis) 690mm x 291mm
   2560x1080     60.00*+ 180.00   144.00   119.88   100.00    59.94
   1920x1080    119.88   100.00    60.00    59.94    50.00
   1680x1050     59.95
   1440x900      59.89
   1280x1024     75.02    60.02
   1280x720     119.88   100.00    59.94    50.00
   1024x768      75.03    70.07    60.00
   800x600       75.00    72.19    60.32    56.25
   720x576       50.00
   720x480       59.94
   640x480       75.00    72.81    59.94
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
USB-C-0 disconnected (normal left inverted right x axis y axis)
HDMI-A-1-0 disconnected (normal left inverted right x axis y axis)
DisplayPort-1-0 disconnected (normal left inverted right x axis y axis)
Hi, at the moment it only supports 2 sizes, the small one 1366X768 and the full screen one.
There is no downsizing.
The problem is understanding why it looks like this on full screen…
Does the small size display everything?
Resizing with the button displays everything which is great but I wish it would start like that.
Sidebar management is not currently implemented, perhaps in the future
I think i had the same problem, changing Display configuration->Global scale back to 100% fixed it and now it fits the screen.
Welcome! We are happy to see you here and hope that you will also find this to be your home.
Welcome to OMLx, @cupakabro!
