Post-edit: Big difference noticed between x86_64 hardware system and znver 1 hw system.
x86_64: dnfdragora-updater simply works with no user intervention
znver1: dnfdragora-updater does not work. So far I have not found any workaround for this.
Konsole output:
$ dnfdragora-updater
File "/usr/lib/python3.7/site-packages/dbus/bus.py", line 177, in activate_name_owner
return self.get_name_owner(bus_name)
File "/usr/lib/python3.7/site-packages/dbus/bus.py", line 363, in get_name_owner
's', (bus_name,), **keywords)
File "/usr/lib/python3.7/site-packages/dbus/connection.py", line 653, in call_blocking
message, timeout)
dbus.exceptions.DBusException: org.freedesktop.DBus.Error.NameHasNoOwner: Could not get owner of name 'org.freedesktop.Notifications': no such name
During handling of the above exception, another exception occurred:
File "/usr/bin/dnfdragora-updater", line 33, in <module>
import dnfdragora.updater
File "/usr/lib/python3.7/site-packages/dnfdragora/updater.py", line 22, in <module>
notify2.init('dnfdragora-updater')
File "/usr/lib/python3.7/site-packages/notify2.py", line 103, in init
'/org/freedesktop/Notifications')
File "/usr/lib/python3.7/site-packages/dbus/bus.py", line 243, in get_object
follow_name_owner_changes=follow_name_owner_changes)
File "/usr/lib/python3.7/site-packages/dbus/proxies.py", line 250, in __init__
self._named_service = conn.activate_name_owner(bus_name)
File "/usr/lib/python3.7/site-packages/dbus/bus.py", line 182, in activate_name_owner
self.start_service_by_name(bus_name)
File "/usr/lib/python3.7/site-packages/dbus/bus.py", line 280, in start_service_by_name
'su', (bus_name, flags)))
message, timeout)
dbus.exceptions.DBusException: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Iāll check this on Lx 4.1 x86_64 hardware system shortly. I make the distinction about hardware system because this works on VBox systems for znver1 and x86_64.
This is working in x86_64 hardware system so problem seems to be specific to znver1 hardware system.
Post-edit: Would be awesomely helpful if we could get confirmation or not of this behavior to see if this is a real problem or specific to my computer for some reason.
This problem has been verified by other people. However I did a fresh install of znver1 and after ādnf --refresh upgradeā the problem occurred again indicating to me that an upgraded package might be the cause.
To reproduce issue on a computer with zen cpu (has to be zen cpu for znver1 to work properly):
I believe you will see dnfdragora-updater is working in āLiveā and on freshly installed system.
Then run ādnf --refresh upgradeā and in my case there was a 120 package upgrade all packages from rolling/main/release repo. After this upgrade dnf-dragora no longer works and produces error in original post. The upgraded packages list:
I knew before filing the bug report this was likely to be a weird one. Partly because of āwhy things that work in x86_64 system on same computer then donāt work in znver1?ā
So now it looks like this was somehow an internet issue not a problem with any package. Why do I think that?
Because a few hours ago I got knocked off the internet, the connection light on modem was blinking not solid like normal. And though computer was showing me connected my router showed me disconnected. So I rebooted cable modem then rebooted router and now this problem has disappeared. Things now appear working normally.
Iām speculating that the above fixed this otherwise I donāt have any explanation for things all of sudden working that havenāt worked for days.
I have no idea as to the cause whether it be dbus, python, dnfdragor-updater, hardware, or perhaps something weird that has happened with all the ācp cooker rollingā upgrades?
If it is the last one then the fix might be to do a fresh install.
This time rebooting cable modem and router is not fixing this.
I think Iāll suppose this is the problem, or something similar regarding upgrade confusion. So Iām going to do a fresh install so this unless the issue returns will be āCanāt Fixā.
