Dnfdragora-2.99.1-1.znver1 requires lib64yui-qt
OpenMandriva Lx release 25.11 (ROME) Rolling for znver1
NAME=“OpenMandriva Lx”
VERSION=“25.11 (ROME) Rolling”
ID=“openmandriva”
VERSION_ID=“25.11”
PRETTY_NAME=“OpenMandriva Lx 25.11 (ROME) Rolling”
BUILD_ID=“20251109.18”
VERSION_CODENAME=“rome”
ANSI_COLOR=“1;43”
LOGO=“openmandriva”
kde/x11
Fresh install from the ISO and went to install dnfdragora and got the following:
$ sudo dnf install dnfdragora
Repositories loaded.
Problem: package dnfdragora-2.99.1-1.znver1 from rolling-znver1 requires lib64yui-qt, but none of the providers can be installed
  • conflicting requests
  • nothing provides libcgraph.so.6()(64bit) needed by lib64yui-qt-4.6.2-8.znver1 from rolling-znver1
  • nothing provides libgvc.so.6()(64bit) needed by lib64yui-qt-4.6.2-8.znver1 from rolling-znver1
    You can try to add to command line:
    –skip-broken to skip uninstallable packages
Thanks @IndieMurph for reporting.
This is fixed in Cooker should be in ROME(rolling) at the next upgrade.
