Let’s make some points:
Clearly not true.
Clearly not true.
PEBKAC issue
Even proud of this (?)
Clearly not true.
Clearly not true.
PEBKAC issue
I have installed finally on dell 3020. Reboot does not work propelly. Cant install wine. Deps problem. Cant install google unstable from repo. Deps issue. On fujitsu esprime p757 solus linux works without problem with kernel 6.10. stupid distro with stupid support. Almost the worse i ever use
When one encounters an issue like this one can take several paths.
Try to resolve the issue. Technical issues require the most knowledgeable people to resolve. Those people may be engaged at OpenMandriva Chat. or by filing a proper bug report with enough detailed information so developers have something they can work on. You did not even try either of these approaches. We can point a user to the best support option but we can not make them use it.
Complain like:
Well I will admit we are not perfect but we are well meaning, hard working people. We really do try to bend over backwards to help users. Also you comment does not explain the many folks using various versions of OMLx every day. Fact: All Linux distros have problems, Solus Linux forum is full of people posting about problems.
