2disbetter
(Rocking Rock 6.0 on a Framework 13 (12th Gen Intel))
1
Rock latest release
KDE
Trying to use Crossover and it is telling me that it needs VTE 2-91, which doesn’t appear to be in the repos.
I am just curious if anyone is able to use Crossover on Openmandriva? Thanks!
dnf search does not show either crossover or vte291 in repos. So probably not. I know we have wine but I think devs are suggesting something called proton for running windows ____. I do not know myself as I do not use any of that.
Is it possible that the vte package needed is named differently in OM?
$ dnf search vte
Last metadata expiration check: 0:01:35 ago on Wed 08 Jan 2025 12:22:00 PM -05.
=========================================================================================== Name Exactly Matched: vte ============================================================================================
vte.znver1 : A terminal emulator widget
========================================================================================== Name & Summary Matched: vte ===========================================================================================
lib64MLIRSPIRVTestPasses-static-devel.znver1 : LLVM MLIRSPIRVTestPasses static library
lib64vte-devel.znver1 : Files needed for developing applications which use VTE
lib64vte-gir0.0.znver1 : GObject Introspection interface description for vte
lib64vte-gir2.91.znver1 : GObject Introspection interface description for vte with GTK+ 3.0
lib64vte-gir3.91.znver1 : GObject Introspection interface description for vte with GTK+ 4.0
lib64vte3-devel.znver1 : Files needed for developing applications which use VTE
lib64vte3-gtk4-devel.znver1 : Files needed for developing applications which use VTE for GTK+ 4
lib64vterm.znver1 : Shared library package of libvterm
lib64vterm-devel.znver1 : Development files of libvterm
lib64vterm0.znver1 : Shared library package of libvterm
libvterm-tools.znver1 : Tools for libvterm
perl-Gnome2-Vte.znver1 : Perl binding for the vte widget
python-vte.znver1 : Python binding for VTE
texlive-revtex4.noarch : TeXLive revtex4 package
vte3-profile.noarch : Profile script for VTE terminal emulator library
=============================================================================================== Name Matched: vte ================================================================================================
lib64vte-gtk4_2.91_0.znver1 : GTK4 terminal emulator library
lib64vte0.0_9.znver1 : A terminal emulator widget
lib64vte2.91_0.znver1 : A terminal emulator widget
rust-vte+default-devel.noarch : Parser for implementing terminal emulators
rust-vte-devel.noarch : Parser for implementing terminal emulators
texlive-fcavtex.noarch : A thesis class for the FCAV/UNESP (Brazil)
texlive-revtex.noarch : Styles for various Physics Journals
texlive-revtex4-1.noarch : Styles for various Physics Journals
vte3.znver1 : A terminal emulator widget
============================================================================================== Summary Matched: vte ==============================================================================================
lxterminal.znver1 : Lightweight VTE-based terminal emulator
texlive-revquantum.noarch : Hacks to make writing quantum papers for revtex4-1 less painful
tym.znver1 : Lua-configurable terminal emulator base on VTE
2disbetter
3
I got the rpm for crossover from the codeweaver website. It is packaged for rpm (so dnf, yum, etc.).
vte291 (vte-2-91) is a dependency it has, and this is why I am looking for it. It doesn’t seem to be in the repo, and I guess I am just asking here if anyone has had and dealt with this issue? I am wondering if maybe I switched to the rolling repo (Rome) if this would then be present there?
Not under that name. There may be a package with a different name in OM repos that will work. My guess would be vte but I am not a developer. Nor do I know the best way to get a package with a different name to work with 3rd party software. Developers are the people to answer these question.
Looking at the “291”/“2-91” name, I’d guess the package you’re looking for is lib64vte2.91_0
2disbetter
7
Thanks my good sir! I have it installed and crossover is still complaining about needing vte291. I will try a restart to see if that does anything, but if not I will just keep working on it.
For any who are interested, the crossover downloads have a 14 day trail by default, so you can mess around to see if you can get it working.
2disbetter
8
So I was able to figure this out. Basically the file in question IS available in the repos:
