After last updates i've noticed that plasma on wayland acts weird. After
some digging i found this when i run glxinfo:
Extended renderer info (GLX_MESA_query_renderer):
Vendor: VMware, Inc. (0xffffffff)
Device: llvmpipe (LLVM 9.0, 256 bits) (0xffffffff)
Version: 19.2.1
Accelerated: no
Video memory: 15874MB
Unified memory: no
Preferred profile: core (0x1)
Max core profile version: 3.3
Max compat profile version: 3.1
Max GLES1 profile version: 1.1
Max GLES[23] profile version: 3.0
OpenGL vendor string: VMware, Inc.
This means Plasma on wayland somehow switches to software renederes instead
of DRM one.
When i run weston glxinfo says i'm running i915 DRM renderer, which is ok.
Digging more in ./local/share/sddm/wayland-session.log with some exported
debug variables (QT_QPA_PLATFORM=wayland-egl EGL_LOG_LEVEL=debug
MESA_DEBUG=1 LIBGL_DEBUG=verbose)
[tpg@tpg-80xl sddm]$ cat wayland-session.log
dbus-update-activation-environment: warning: error sending to systemd:
org.freedesktop.DBus.Error.ServiceUnknown: The name
org.freedesktop.systemd1 was not provided by any .service files
QCommandLineParser: already having an option named "h"
QCommandLineParser: already having an option named "help-all"
QCommandLineParser: already having an option named "v"
No backend specified through command line argument, trying auto resolution
_XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
_XSERVTransMakeAllCOTSServerListeners: server already running
libGL: Can't open configuration file /etc/drirc: No such file or directory.
libGL: Can't open configuration file /home/tpg/.drirc: No such file or
directory.
libEGL debug: pci id for fd 7: 8086:5917, driver i965
libEGL debug: MESA-LOADER: dlopen(/usr/lib64/dri/i965_dri.so)
libEGL debug: found extension `DRI_Core'
libEGL info: found extension DRI_Core version 2
libEGL debug: found extension `DRI_IMAGE_DRIVER'
libEGL info: found extension DRI_IMAGE_DRIVER version 1
libEGL debug: found extension `DRI_DRI2'
libEGL debug: found extension `DRI_DriverVtable'
libEGL debug: found extension `DRI_ConfigOptions'
libEGL info: found extension DRI_ConfigOptions version 1
directory.
directory.
libEGL debug: found extension `DRI_TexBuffer'
libEGL info: found extension DRI_TexBuffer version 3
libEGL debug: found extension `DRI2_Fence'
libEGL debug: found extension `DRI2_Flush'
libEGL info: found extension DRI2_Flush version 4
libEGL debug: found extension `DRI_IMAGE'
libEGL info: found extension DRI_IMAGE version 16
libEGL debug: found extension `DRI_RENDERER_QUERY'
libEGL debug: found extension `DRI_MutableRenderBufferDriver'
libEGL debug: found extension `DRI_CONFIG_QUERY'
libEGL debug: found extension `DRI_Robustness'
libEGL debug: found extension `DRI_NoError'
libEGL debug: found extension `DRI2_Blob'
libEGL info: found extension DRI2_Fence version 2
libEGL info: found extension DRI_RENDERER_QUERY version 1
libEGL info: found extension DRI_MutableRenderBufferDriver version 1
libEGL info: found extension DRI_CONFIG_QUERY version 1
libEGL info: found extension DRI_Robustness version 1
libEGL info: found extension DRI_NoError version 1
libEGL info: found extension DRI2_Blob version 1
libEGL debug: did not find optional extension DRI2_BufferDamage version 1
libEGL debug: did not find optional extension DRI2_Interop version 1
libEGL debug: did not find optional extension DRI_FlushControl version 1
glamor: No eglstream capable devices found
glamor: 'wl_drm' not supported
Missing Wayland requirements for glamor GBM backend
Missing Wayland requirements for glamor EGLStream backend
Failed to initialize glamor, falling back to sw
directory.
directory.
The XKEYBOARD keymap compiler (xkbcomp) reports:
Warning: Unsupported high keycode 372 for name <I372> ignored
X11 cannot support keycodes above 255.
This warning only shows for the first high keycode.
Errors from xkbcomp are not fatal to the X server
libKF5KIOCore.so.5 was not found.
libKF5Parts.so.5 was not found.
libKF5Plasma.so.5 was not found.
kdeinit5: preparing to launch '/usr/lib64/libexec/kf5/klauncher'
kdeinit5: Launched KLauncher, pid = 20907, result = 0
Googling around gives nothing ![]()
No i have to use x11 session.
