The iiso-builder should enable the unsupported repo now with the use of the --unsupprepo flag. In addition the testing repo is also supported when adding the --testing flag. An --enablerepo= flag is also provided but this has not yet been tested for multiple repos.Please test.
Best,Colin
Hi AngryPenguin. I’ll take look later tonight. I ran out of time to test the new flags as there was other stuff to do and I wanted to get it out.
That’s a strange error though!
Best,
Colin
Hi,
For some reason it still failed though it worked in ABF mode locally. I’ll be back home later today so I’ll check it out. Not sure what the issue could be but it’s ABF dependant what ever it is.
Best,
Colin
/bin/rm: cannot remove
'/home/ruru/omdv-build-chroot-x86_64/BASE/etc/yum.repos.d/*.repo': No
such file or directory
error: File not found by glob: *.rpm
ls: cannot access
'/home/ruru/omdv-build-chroot-x86_64/BASE/etc/yum.repos.d': No such
file or directory
x86_64
Repo dir bad install.
-> Something went wrong.
Exiting
