Hi Folks,
In order for me to make the fulltime switch over to OM there are a few programs that I’ll be needing that aren’t in the repo.
While flatpacks and appimages can fill in for some things, I find that even when they are available I wind up compiling anyway after a “trial run”.
Before I go down that particular bunny trail I figured I’d check and see if there were any specific OM related libraries I needed.
For instance over on Mint (my current DD) “build-essential” is a required package.
I see that checkinstall is in the repo
Or can I just compile my happy little head off
Thanks
Ref: https://forums.linuxmint.com/viewtopic.php?t=230142
I don’t know what a DD is, but we have a package that basically does what you are asking:
https://openmandriva.pkgs.org/cooker/openmandriva-main-release-x86_64/basesystem-build-4-31-omv2390.x86_64.rpm.html
It should include just about everything you would need to build something in OMLx.
sudo dnf in basesystem-build
We also have packaging tools if you decide you want to share your work with others.
vannax
(Mike)
August 7, 2025, 2:41am
3
I believe DD is “Daily Driver.”
::sigh:: you know, I ran that search and nothing came up.
It’s been that kinda day.
Thank you.
Could you share more about those packaging tools? I’m going be in a need to build some packages and will be more than happy to share with others.
You typically want the previously mentioned package, rpmdevtools and packaging-tools. If you want to develop with the kernel (or any other library) you’ll need the respective devel package.
system
(system)
Closed
September 6, 2025, 9:36pm
9
