Codecs cannot be installed
I have been trying to install the codecs provided by OM-Welcome for a few days now.
They couldn’t be installed and after trying to install its packages all together i have found the error.
Certain libraries are not provided for install thus the install always fails.
I have made this issue over on github as will be linked to at the end of the post.
  • OpenMandriva Lx version:
    ROME
    KDE
    Codecs cannot be installed thanks to the following error described bellow and above.
    Latest Distro Sync, Laptop Samsung NP300E5M with no modified hardware aside from having a sata SSD instead of an HDD.
Output of Dnfdrake install:
Error:
Problem: conflicting requests
  • nothing provides libavutil.so.57()(64bit) needed by x264-0.164-0.20220601.2.x86_64 from rolling-x86_64-restricted
  • nothing provides libavutil.so.57(LIBAVUTIL_57)(64bit) needed by x264-0.164-0.20220601.2.x86_64 from rolling-x86_64-restricted
  • nothing provides libavcodec.so.59()(64bit) needed by x264-0.164-0.20220601.2.x86_64 from rolling-x86_64-restricted
  • nothing provides libavcodec.so.59(LIBAVCODEC_59)(64bit) needed by x264-0.164-0.20220601.2.x86_64 from rolling-x86_64-restricted
  • nothing provides libavformat.so.59()(64bit) needed by x264-0.164-0.20220601.2.x86_64 from rolling-x86_64-restricted
  • nothing provides libavformat.so.59(LIBAVFORMAT_59)(64bit) needed by x264-0.164-0.20220601.2.x86_64 from rolling-x86_64-restricted
  • nothing provides libswscale.so.6()(64bit) needed by x264-0.164-0.20220601.2.x86_64 from rolling-x86_64-restricted
  • nothing provides libswscale.so.6(LIBSWSCALE_6)(64bit) needed by x264-0.164-0.20220601.2.x86_64 from rolling-x86_64-restricted
    (try to add ‘–skip-broken’ to skip uninstallable packages).
Github Issue 2928:
You will find a convenient shortcut in OM Welcome
If you carefully read my post you will find that that route has been tried, but as it is nothing more than a fancy script to do the manual job the dnfdrake bug report still stands. The codecs cannot be installed, put simply. (Deleted the other post in order to put a proper reply but it did basically read the same as this.)
Yes I misunderstood the first line.
I can confirm, running om-welcome from console I can see the output with failed transaction.
It will be reported to devs. May need just a rebuild.
Postedit:
The issue is working on. Meanwhile you can install all the codecs except x264
faac flac lib64xvid4 lib64dca0 x265 lib64dvdcss2 qt-heif-image-plugin heifthumbnailer
Thanks for that, got to install everything except x264 just like you said, which is a huge help already.
You can install the cooker fixed package in ROME
sudo dnf install --enablerepo=cooker-x86_64-restricted x264
My log:
x264.txt (4,3 KB)
Won’t it cause problems with the distrosync under ROME?
EDIT: Read the message in the github issue and it seems to be a one time things, thanks!
Will still do it, but that’s my concern
Sure :wink:
I posted my concern on closing, if any of the mods or devs feel that this solves the bug in a more permanent manner then feel free to close the issue and put your last post as a solution.
I have labeled it as solved in cooker. For ROME is not solved yet but will become with next major upgrade.
No.
Try it and see. If there is any problem there would be an error message so no harm would be done.
Thanks for the hard work.
