ClipBucket and SuperDesk
Hi,
I tried to install ClipBucket and SuperDesk some of the packages giving issues.
[root@Pujitha-PC ~]# lsb_release -a
LSB Version: *
Distributor ID: OpenMandrivaLinux
Description: OpenMandriva Lx 4.0
Release: 4.0
Codename: Nitrogen
For ClipBucket
https://clipbucket.com/docs/installation/
Upto now giving errors in MariaDB Server and Install PHP and Extensions.
System.txt (1.6 KB)
out.txt (178.0 KB)
MariaDB-server.txt (4.0 KB)
[root@Pujitha-PC ~]# sudo systemctl enable nginx && sudo systemctl start nginx
Job for nginx.service failed because the control process exited with error code.
See “systemctl status nginx.service” and “journalctl -xe” for details.
For SuperDesk Still checking..
superdesk README.md.txt (5.3 KB)
Having issues when installing phpMyAdmin too.
Failed to enable unit: Unit file nginx.service does not exist.
FYA.
Thanks,
Pujitha
https://www.superdesk.org/news/installing-superdesk-publisher
maybe not related to this but Firefox and Brave crash. Can not go to internet. Chrome too…
I execute
dnf autoremove
after the last system update.
[Dimuthu@Pujitha-PC ~]$ firefox
Exiting due to channel error.
I don’t have any answers for clipbucket or superdesk. For those you would need to go to Freenode IRC channel #openmandriva or maybe #openmandriva-cooker. (That is so you can talk directly to developers. Be patient, we are a small group, but someone will get to your issue eventually.)
I’m in OM Lx 4.0 right now with Firefox running so don’t think it is an OM problem. Chromium, Falkon, Quassel, and Thunderbird are all working here.
Informed both parties with a link to this group post.
