The idea is to tell clamscan to inform only infected files. This is done simply by,
clamscan -r -i /
I add to it,
clamav -r -i / >infectados.txt 2>&1
to have the result in a file for later analysis. The resulting file is 1.6M and since everybody can get this using the command above, I’ll not upload it unless told to.
The result is somewhat surprising. The infected files are all clamav’s itself testing files (list in the end). However, I got hundreds of warnings, on the use of pcre and the fact that its support is disabled, an example is
LibClamAV Warning: cli_loadldb: logical signature for Email.Trojan.Toa-5493306-0 uses PCREs but support is disabled, skipping
also, even as root, some files had permission denied. Examples are,
WARNING: Can't open file /sys/devices/pci0000:00/0000:00:1a.0/rescan: Permission denied
and other error messages. Are there problems with clamav installation?
Finally, the list of “infected files”,
/usr/share/doc/clamav/test/clam-petite.exe: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.odc.cpio: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.mail: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.bin-le.cpio: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.exe.bz2: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/.split/split.clam_IScab_int.exeaa: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/.split/split.clam_IScab_ext.exeaa: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/.split/split.clamjol.isoaa: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/.split/split.clam.isoaa: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam-aspack.exe: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.exe.mbox.base64: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.newc.cpio: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.tnef: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.pdf: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam_ISmsi_ext.exe: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.ea06.exe: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.exe.rtf: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.d64.zip: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.exe.szdd: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clamjol.iso: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.chm: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam_IScab_ext.exe: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam-wwpack.exe: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.7z: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.ole.doc: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam_IScab_int.exe: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.cab: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam_ISmsi_int.exe: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam-nsis.exe: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.iso: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.impl.zip: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam-fsg.exe: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam-upx.exe: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.bin-be.cpio: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam-mew.exe: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.zip: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.arj: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.ea05.exe: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam_cache_emax.tgz: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam-upack.exe: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.bz2.zip: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.exe: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.exe.binhex: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.sis: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.tar.gz: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.exe.html: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam-yc.exe: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.exe.mbox.uu: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam-pespin.exe: Clamav.Test.File-6 FOUND
/usr/share/doc/clamav/test/clam.ppt: Clamav.Test.File-6 FOUND
