Certificato scaduto?
 [~]$ sudo LC_ALL=C dnf clean all ; sudo  dnf  dsync 2>&1 | tee $(date -I)-dsync-log.txt
[sudo] password:
Removed 0 files, 4 directories (total of 0 B). 0 errors occurred.
 OpenMandriva Rolling - Non-free - x86_ ???% |   0.0   B/s |   0.0   B |  00m04s
>>> Curl error (60): SSL peer certificate or SSH remote key was not OK for https://abf-downloads.openmandriva.org/rolling/repository/x86_64/non-free/release/repodata/repomd.xml [SSL certificate OpenSSL verify result: certificate has expired (10)] - https://abf-downloads.openmandriva.org/rolling/repository/x86_64/non-free/release/repodata/repomd.xml
>>> Usable URL not found
 OpenMandriva Rolling - Restricted - x8 ???% |   0.0   B/s |   0.0   B |  00m04s
>>> Curl error (60): SSL peer certificate or SSH remote key was not OK for https://abf-downloads.openmandriva.org/rolling/repository/x86_64/restricted/release/repodata/repomd.xml [SSL certificate OpenSSL verify result: certificate has expired (10)] - https://abf-downloads.openmandriva.org/rolling/repository/x86_64/restricted/release/repodata/repomd.xml
 OpenMandriva Rolling - Extra - x86_64  ???% |   0.0   B/s |   0.0   B |  00m04s
>>> Curl error (60): SSL peer certificate or SSH remote key was not OK for https://abf-downloads.openmandriva.org/rolling/repository/x86_64/extra/release/repodata/repomd.xml [SSL certificate OpenSSL verify result: certificate has expired (10)] - https://abf-downloads.openmandriva.org/rolling/repository/x86_64/extra/release/repodata/repomd.xml
 OpenMandriva Rolling - x86_64          ???% |   0.0   B/s |   0.0   B |  00m02s
>>> Curl error (60): SSL peer certificate or SSH remote key was not OK for https://abf-downloads.openmandriva.org/rolling/repository/x86_64/main/release/repodata/repomd.xml [SSL certificate OpenSSL verify result: certificate has expired (10)] - https://abf-downloads.openmandriva.org/rolling/repository/x86_64/main/release/repodata/repomd.xml
Repository caricati.
Nessuna operazione da eseguire.
Grazie. Si.
Chi di dovere è già stato avvisato.
I certificati “”“dovrebbero”“” rinnovarsi automaticamente ma pare che non sempre funzioni :slight_smile:
Risolto.
A Voi sempre grazie.
