Can't remove Yakuake from my Rolling system
  • _OpenMandriva Lx version:_25.01 ROME
  • Desktop environment (KDE, LXQT…): LXQT, KDE
Hallo,
it is impossibe to remove yakuake.
$ sudo dnf remove yakuake
Keine Übereinstimmung für Argumente: yakuake
Keine Pakete zum Entfernen markiert.
Abhängigkeiten sind aufgelöst.
Nichts zu tun.
Fertig!
But ‘yakuake’ is installed in my system.
$ dnf list yakuake
google-earth-pro        1.5 kB/s | 1.0 kB     00:00
OpenMandriva Rolling - x86_64        2.0 MB/s | 5.4 MB     00:02
OpenMandriva Rolling - Extra - x86_64        754 kB/s | 1.4 MB     00:01
OpenMandriva Rolling - Restricted - x86_64        18 kB/s |  23 kB     00:01
OpenMandriva Rolling - Non-free - x86_64        24 kB/s |  30 kB     00:01
Verfügbare Pakete
yakuake.x86_64
with regards
Ch. Hanisch
When I search and translate that, it comes as “Available Packages”
I don’t think that means it is installed, but it sees it in the repos. Try
which yakuake
rpm -qa|grep yakuake
most likely it will return
plasma6-yakuake
I uninstalled mine a week ago and it returns nothing. I expect @Hanisch will get the same result.
If you use dnf list installed "*yakuake*" dnf will return the full package.arch name of yakuake that is installed, if it is not installed the command will return nothing.
From there you should be able to for example: sudo dnf remove plasma6-yakuake.x86_64 or in my case it would be sudo dnf remove plasma6-yakuake.znver1 using the full package name to remove yakuake.
Console log:
  uro  ~  $ dnf list installed "*yakuake*"
Installed Packages
plasma6-yakuake.znver1                                                24.12.1-1                                                 @rolling-znver1
  uro  ~  $ sudo dnf remove plasma6-yakuake.znver1
[sudo] password for uro:
Dependencies resolved.
 Package                              Architecture                Version                           Repository                            Size
Removing:
 plasma6-yakuake                      znver1                      24.12.1-1                         @rolling-znver1                      2.3 M
Transaction Summary
Remove  1 Package
Freed space: 2.3 M
Is this ok [y/N]:
I hope this is of use for your quest.
$ sudo dnf remove plasma6-yakuake.x86_64
with this strangely name the “Yakuake”-package is successful removed.
Why is the name of “Yakuake” so different in any systems?
with regards
Ch. Hanisch
Great question!
The upgrade from Plasma 5 to plasma 6 is not complete. They are still updating packages too. Some of them still use parts of Plasma5 and some use parts of Plasma6 and they have to be flagged in some way.
Once all of that is complete, they will drop all the extra parts of the names that signify what they are.
