OpenMandriva Lx version: 3.02
Desktop environment (KDE, LXQT…): Plasma
Description of the issue (screenshots if relevant): Can’t put on work my wireless.
Relevant informations (hardware involved, software version, logs or output…): hardware wireless BCM43142A0
After a fresh install my wireless card doesn’t work. I go to Drakconnect -> wireless and select the card, it try to install dkms-broadcom-wl but fail with the next output.
retrieving rpm files from medium “non-free updates”…
http://downloads.openmandriva.org/mirrors/openmandriva.3.0.x86_64.list: media/non-free/updates/dkms-broadcom-wl-6.30.223.271-2-omv2015.0.x86_64.rpm
69% of 1.4MiB completed, ETA = 1s, speed = 434KiB retrieved ftp://openmandriva.c3sl.ufpr.br/openmandriva/3.0/repository/x86_64/media/non-free/updates dkms-broadcom-wl-6.30.223.271-2-omv2015.0.x86_64.rpm
…retrieving done
installing dkms-broadcom-wl-6.30.223.271-2-omv2015.0.x86_64.rpm from /var/cache/urpmi/rpms
starting installing packages
created transaction for installing on / (remove=0, install=0, upgrade=1)
Creating symlink /var/lib/dkms/broadcom-wl/6.30.223.271-2/source ->
/usr/src/broadcom-wl-6.30.223.271-2
DKMS: add completed.
Kernel preparation unnecessary for this kernel. Skipping…
Building module:
cleaning build area…
make KERNELRELEASE=4.13.8-desktop-1omv -j8…(bad exit status: 2)
Error! Bad return status for module build on kernel: 4.13.8-desktop-1omv (x86_64)
Consult /var/lib/dkms/broadcom-wl/6.30.223.271-2/build/make.log for more information.
Building module:
ERROR: ‘script’ failed for
error: %post(dkms-broadcom-wl-6.30.223.271-2.x86_64) scriptlet failed, exit status 10
I have the current kernel 4.13.8-desktop-1omv and sources at /usr/src/linux-4.13.8-desktop-1omv.
Output of the make log at /var/lib/dkms/broadcom-wl/6.30.223.271-2/build/make.log show a compile error “wl_linux.c:2918:10: error: ‘struct net_device’ has no member named ‘last_rx’”.
Any help?
