Burn a disc with brasero
i tried burning some audio discs with brasero but i was unable too and i ended up wating some blank cds
now, as some of you brasero is unmaintained and bugged as (per gnome developers) "nobody burns cds anymore), but still for what it’s worth, it works and i always burned records with that
i had used brasero in fedora and at the beginning it wasn’t working too, so devs asked me to put this command into terminal to give brasero the right permissions
sudo chmod u+s /usr/bin/wodim
and with that it worked perfectly
yesterday anyway i wasn’t able to use brasero on openmandriva so i thought about trying the same command as it might have been the same problem, but dnf says that wodim can’t be found and cdrkit should be installed for wodim to be installed
so now, does anybody knows on what brasero relies?would installing cdrkit solve my problem?
Edit: tried installing cdrkit and it asks me to remove cdrtools, but i don’t know if it’s safe or not…
thank you
