First I wish to thank all of OM’s developers for bringing Mandriva alive!
I’m running OM Lx 4.1 Mercury on a MacBook Pro mid 2012 and all is working from installation to its use
The only thing I can’t get is full speed with the internal wifi card which is a Broadcom BCM4331 as I couldn’t find a way to install the broadcom-wl driver (actually using b43 but this driver doesn’t offer 5GHz for N-PHY cards).
IRC for users is #openmandriva @ Freenode IRC. You and all users are welcome there.
The broadcom-wl driver is proprietary so that may be a problem that OM can not over come. Edit: But I’m not sure about that. We are smaller and have fewer resources than Mandriva did. We are all volunteer, unpaid contributors.
Hello ben79,
Thanks for replying. I’ve downloaded the tarball but I’m clueless about what to do with these files.
Here are the listing of this tarball:
~/Téléchargements/broadcom-wl-5.100.138 $ ls -alRh
total 20K
drwxr-xr-x 4 matt matt 4,0K août 13 2011 .
drwxr-xr-x 3 matt matt 4,0K août 27 09:45 ..
drwxr-xr-x 2 matt matt 4,0K août 13 2011 config
drwxr-xr-x 2 matt matt 4,0K août 13 2011 linux
-rw-r--r-- 1 matt matt 292 août 13 2011 README
./config:
total 56K
drwxr-xr-x 2 matt matt 4,0K août 13 2011 .
drwxr-xr-x 4 matt matt 4,0K août 13 2011 ..
-rw-r--r-- 1 matt matt 993 août 13 2011 wlconfig_lx_shared
-rw-r--r-- 1 matt matt 960 août 13 2011 wlconfig_nomimo
-rw-r--r-- 1 matt matt 1,4K août 13 2011 wl_default
-rw-r--r-- 1 matt matt 999 août 13 2011 wl_hnd
-rwxr-xr-x 1 matt matt 30K août 13 2011 wl.mk
./linux:
total 36M
-rwxr-xr-x 1 matt matt 12M août 13 2011 wl_ap.o
-rwxr-xr-x 1 matt matt 13M août 13 2011 wl_apsta.o
-rwxr-xr-x 1 matt matt 12M août 13 2011 wl_sta.o
The README is of no help:
~/Téléchargements/broadcom-wl-5.100.138 $ cat README
This driver was extracted out of the GPL source package for NETGEAR WNDR4500
It contains the Broadcom wireless driver 5.100.138
This driver includes firmware version 666.2
http://www.downloads.netgear.com/files/GPL/WNDR4500-V1.0.0.40_1.0.10_src.tar.zip
WNDR4500-V1.0.0.40_1.0.10_src/src/wl
If you want OpenMandriva to package broadcom-wl (if the license allows) you need to ask developers. I asked on IRC about this and did not get an answer. You could go to IRC yourself and ask.
There is a place in this forum to make package requests here.
Hi ben79,
I really appreciate all of your advices regarding my issue. I’ll try first to check and do steps on 01.org’s tutorial.
If i succeed, I’ll report back on this thread to mark it as solved. Otherwise, I’ll poke people on irc and as a last resort, I’ll ask a package request at OM’s developers if the license allows it.
You might set up an account at our issue tracker and follow that package request. And then you are all set if you have any other issue that rises to bug report level.
Please do this. I definitely find that the squeaky wheel gets the grease. I don’t expect the license to be a problem but it was mentioned I think on Github. Developers will know the answer to that.
