Brief How-to Podman / Distrobox installation / configuration
  • OpenMandriva Lx version:
    rome
    KDE6
    Install podman and distrobox plus configuration
I am no expert at all but this worked for me
First install podman
If you install distrobox first it installs docker as dependency but will notif podman is already installed.
sudo dnf install podman crun
Installing distrobox separately just because I do not want distrobox dependency to pull docker
sudo dnf install distrobox
sudo touch /etc/subuid
sudo touch /etc/subgid
sudo usermod --add-subuids 200000-265536 --add-subgids 200000-265536 $USER
check if there are >1000 user namespaces
sysctl --all --pattern user_namespaces
if not, or I suppose just to be safe
sudo nano /etc/sysctl.d/userns.conf
in this file add
user.max_user_namespaces=28633
podman system migrate
now distrobox, and podman, should work on Openmandriva
I should link the youtube video I mostly followed.
@corbyr Thank you.
