(posting it here as I couldn’t find a better place, please move if necessary)
I started to make the OMA Welcome tool look more like a Plasma application. Changing colors, buttons, fonts etc. Furthermore I started to swap PNG files for SVGs to make everything HiDPI proof. It’s not finished yet and needs some fine tuning but I thought I’d share it here.
Yes, I am replacing over the time the png icons with their svg version. Not all of them have an svg available though, but mostly already done.
I like the new look.
[ruru@ruru-omlx4 oma-welcome]$ /usr/bin/htmlscript -s 870x550 -i /usr/share/icons/openmandriva.svg -t "OM Welcome" index.sh.htm
Nouveau openGL driver detected. Qt WebEngine will disable usage of the GPU.
Please consider getting hardware not made by NVIDIA.
Alternatively, you can set the QT_WEBENGINE_DISABLE_NOUVEAU_WORKAROUND
environment variable before running this application, but this is
not recommended since this usually causes applications to crash as
Nouveau openGL drivers don't support multithreaded rendering
libpng warning: iCCP: known incorrect sRGB profile
Yeah, please follow what Qt WebEngine says: avoid Nvidia stuff at all cost.
That’s something already appearing with the currently packaged and shipped version in OMLx4. It’s the icon of Applications => Multimedia => Codecs which has an built-in color profile. I fixed that now by recreating the PNG file but the icon itself should be replaced as it’s nowhere available as SVG.
