Borgbackup blocca l'aggiornamento
$ inxi -b System:   Host: tosh64 Kernel: 6.17.7-server-1omv2590 arch: x86_64 bits: 64   Desktop: KDE Plasma v: 6.5.2 Distro: OpenMandriva Lx 25.11 ROME Machine:   Type: Laptop System: Notebook product: NJx0PU v: N/A     serial: <superuser required>   Mobo: Notebook model: NJx0PU serial: <superuser required> UEFI: INSYDE     v: 1.07.06 date: 06/08/2023 Battery:   ID-1: BAT0 charge: 42.6 Wh (87.7%) condition: 48.6/45.9 Wh (105.9%) CPU:   Info: 10-core (2-mt/8-st) 12th Gen Intel Core i7-1255U [MST AMCP]     speed (MHz): avg: 731 min/max: 400/4700:3500 Graphics:   Device-1: Intel Alder Lake-UP3 GT2 [UHD Graphics] driver: i915 v: kernel   Device-2: Bison BisonCam NB Pro driver: uvcvideo type: USB   Display: x11 server: X.org with: Xwayland v: 24.1.9 driver: X:     loaded: modesetting unloaded: fbdev,vesa dri: iris gpu: i915 resolution:     1: 1680x1050~60Hz 2: 1920x1080~60Hz   API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.3.0-rc4     renderer: Mesa Intel Graphics (ADL GT2)   Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo de: kscreen-console     wl: wayland-info x11: xdpyinfo, xprop, xrandr Network:   Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi   Device-2: Intel Ethernet I219-V driver: e1000e   Device-3: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB Drives:   Local Storage: total: 931.52 GiB used: 265.51 GiB (28.5%) Info:   Memory: total: 16 GiB note: est. available: 15.34 GiB used: 4.78 GiB (31.2%)   Processes: 386 Uptime: 3d 21h 35m Shell: Bash inxi: 3.3.39
]$ sudo dnf clean all ; sudo LC_ALL=C dnf -x borgbackup  dsync 2>&1 | tee $(date -I)-dsync-log.txt
Removed 12 files, 12 directories (total of 23 MiB). 0 errors occurred.
 OpenMandriva Rolling - Non-free - x86_ 100% |  20.9 KiB/s |  33.5 KiB |  00m02s
 OpenMandriva Rolling - Restricted - x8 100% |  23.5 KiB/s |  38.7 KiB |  00m02s
 OpenMandriva Rolling - Extra - x86_64  100% | 498.0 KiB/s |   1.5 MiB |  00m03s
 OpenMandriva Rolling - x86_64          100% |   1.3 MiB/s |   5.9 MiB |  00m04s
Repositories loaded.
Problem: installed package borgbackup-1.4.0-1.x86_64 requires (python3.11dist(msgpack) <= 1.1 with python3.11dist(msgpack) >= 1.0.3), but none of the providers can be installed
  - python-msgpack-1.1.0-1.x86_64 does not belong to a distupgrade repository
  - problem with installed package
You can try to add to command line:
  --skip-broken to skip uninstallable packages
Nemmeno «–skip-broken» aiuta, La risposta è sempre la stessa:
Serve un aiuto competente. Grazie.
Sbagliavo volendo escludere «-x borgbackup» dall’aggiornamento.
Invece il modo corretto è escludere «-x python-msgpack-1.1.0-1.x86_64».
Ecco il comando usato.
sudo dnf clean all ; sudo  dnf -x python-msgpack-1.1.0-1.x86_64  dsync 2>&1 | tee $(date -I)-dsync-log.txt
Ecco il log. (S.Lucia funziona!)
2025-12-13-dsync-log.txt (475.0 KB)
