Giorgio
(Giorgio)
May 13, 2020, 5:46am
1
openMandriva doesn’t boot.
After yesterday system update boot stop and I get an error message.
The last row of error message is something like:
acpi MSFT0101:00 platform device creation failed: -16
(rugyada)
May 13, 2020, 7:18am
2
There were no updates yesterday afaik.
Giorgio
(Giorgio)
May 13, 2020, 4:04pm
3
Yesterday I updated few packages, may be they are several days old. But almost sure that the problem appears just after update then probably the origin is in updated packages.
(rugyada)
May 13, 2020, 4:10pm
4
Then you know what to do: the list of latest packages updated.
Giorgio
(Giorgio)
May 13, 2020, 4:21pm
5
I know what I’d do. But boot hang then OMLx don’t start, how is possible to make this list?
If useful I remember that for one of these packages was possible to keep old settings (default) or change with new ones. May be the package is “sdd” ?
(rugyada)
May 13, 2020, 4:54pm
6
Is you system English or Italian locales ?
(rugyada)
May 13, 2020, 5:43pm
8
Try:
At GRUB screen
Advanced Options for… > OpenMandriva Lx … (console mode)
At terminal prompt, login. Then type command
rpm -qa --last | grep mar\ 5\ mag
If you can get the terminal, you should be able to read there the few packages installed yesterday.
Giorgio
(Giorgio)
May 13, 2020, 7:37pm
9
Here’s yesterday updates:
oma-welcome-2.1.25-1.noarch mar 12 mag 2020, 23:08:06
microcode-intel-20200508-1.noarch mar 12 mag 2020, 23:08:06
sddm-0.18.1-6.20200507.4.x86_64 mar 12 mag 2020, 23:08:05
rng-tools-6.10-2.x86_64 mar 12 mag 2020, 23:08:05
ben79
(Ben Bullard)
May 13, 2020, 8:34pm
10
Update: I have tested this and downgrading sddm works.
Try this: Log in to console mode again and:
$ sudo dnf downgrade sddm
reboot and see if that affects anything.
Post-edit : This package:
is only in main/testing so I would suggest to disable testing repositories. (All of the packages in @Giorgio ’s list are in main/testing repo.)
(rugyada)
May 13, 2020, 8:41pm
11
Giorgio:
Please post output of:
$ sudo dnf clean all;dnf clean all;dnf repolist
Postedit:
oh, if it’s too hard to do (sorry) please at least write which repos it says are enabled.
Giorgio
(Giorgio)
May 14, 2020, 6:17am
12
Here’s what I get
id repo nome repo
rock-testing-x86_64 OpenMandriva Rock - x86_64 - Testing
rock-testing-x86_64-non-free OpenMandriva Rock - Non-free - x86_64 - Testing
rock-testing-x86_64-restricted OpenMandriva Rock - Restricted - x86_64 - Testing
rock-testing-x86_64-unsupported OpenMandriva Rock - Unsupported - x86_64 - Testing
rock-updates-x86_64-non-free OpenMandriva Rock - Non-free - x86_64 - Updates
rock-updates-x86_64-restricted OpenMandriva Rock - Restricted - x86_64 - Updates
rock-updates-x86_64-unsupported OpenMandriva Rock - Unsupported - x86_64 - Updates
rock-x86_64-non-free OpenMandriva Rock - Non-free - x86_64
rock-x86_64-restricted OpenMandriva Rock - Restricted - x86_64
rock-x86_64-unsupported OpenMandriva Rock - Unsupported - x86_64
Giorgio
(Giorgio)
May 14, 2020, 6:20am
13
ben79:
This solved partially. Boot worked one time.
Then I set autologin and now it hang again. Not in the same way as before. Now it stops showing a window similar to konsole with white background. No menu.
(rugyada)
May 14, 2020, 10:25am
14
ok
Type there:
$ cat /etc/sddm.conf
at line 3, should be:
Session=plasma
at line 11, should be:
[Theme]
Current=breeze
if not, edit it.
$ sudo nano /etc/sddm.conf
Giorgio:
Here’s what I get
Yep, it confirms my early suspect, it’s the reason why I asked
Common users should never enable /testing repos in stable release.
If ever/when there is the rare needing, just enable for current transaction and disable it immediately after.
Now, once you can get back to plasma desktop please run om-repo-picker utility and disable whatever except main.
run again the holy command
Hope this helps. Good luck.
Giorgio
(Giorgio)
May 14, 2020, 6:13pm
15
This is my sddm.conf after edit sddm.conf.txt (912 Byte) but unfortunately nothing change.
(rugyada)
May 14, 2020, 6:45pm
16
This is mine, from OMLx 4.1 machine
https://pastebin.com/XvqG17Sj
Giorgio
(Giorgio)
May 14, 2020, 7:26pm
17
Compared mine and your sddm.conf show few differences. I added few lines with no result.
I solved moving Session=plasma almost at the beginning:
[Autologin]
Relogin=false
Session=plasma
[General]
InputMethod=
Numlock=none
Now it seems that all works. Thanks.
(rugyada)
May 14, 2020, 7:29pm
18
Great!
Hope it keeps working.
Time to fix repos in om-repo-picker
Giorgio
(Giorgio)
May 14, 2020, 7:41pm
19
Just tried to set autologin but this setting isn’t saved. Anyway OMLx seems working.
id repo nome repo
(rugyada)
May 14, 2020, 8:03pm
20
Your system was a bit messed so I’d suggest to let it as is now and use it for a while. Then to deal with one issue at time.
