Bluetooth Not Working - Beelink EQR
  • OpenMandriva Lx version: 25.03
  • Desktop environment (KDE, LXQT…): KDE 6.3.2
  • Relevant information (hardware involved, software version, logs or output…): Beelink EQR Mini PC, Ryzen 9 6900HX, 24g DDR5 4800Mhz
Greetings! I am new to OpenMandriva and excited to give it a real try as my main OS. Recently, I
purchased a Beelink EQR Mini PC and installed OM 25.03 on it. At first, the Wifi would not work, but then I did further updates and it is now working. However, the Bluetooth will not connect to anything. It is enabled but only shows addresses for the devices and not their names. It will not connect to anything at all.
I contacted Beelink but they just pointed me to kernal.org. I suspect that is not a real solution since I’m already running the 6.14 r4 kernal. Any help would be greatly appreciated!
I am a bit confused. I am running the latest version of ROME and I have
Kernel: Linux 6.13.5-desktop-1omv2590
Could you please post the output of
dnf repolist
Sure. Here you go. By the way, my Bluetooth adapter is Intel AX200.
rolling-x86_64-extra OpenMandriva Rolling - Extra - x86_64
rolling-x86_64-non-free OpenMandriva Rolling - Non-free - x86_64
I am trying to figure out where you got the 6.14 r4 kernel. How did you do your updates?
By the way, Welcome! We hope you will make this your home.
Thank you for the welcome! I did the update according to the new user instructions on the OpenMandriva website.
Also, I’ve been trying to check my firmware, but getting nowhere. It looks like it isn’t installed properly. When I try to add it from the repo, it says it doesn’t exist.
Here:
[mattheww@openmandriva-x8664 ~]$ sudo dnf install linux-firmware
Last metadata expiration check: 1:04:29 ago on Sat 08 Mar 2025 09:07:39 AM EST.
No match for argument: linux-firmware
Error: **Unable to find a match: linux-firmware**
[mattheww@openmandriva-x8664 ~]$ sudo modprobe -r btusb && sudo modprobe btusb
[mattheww@openmandriva-x8664 ~]$ dmesg | grep -i bluetooth
[Sat Mar  8 06:54:01 2025] Bluetooth: Core ver 2.22
[Sat Mar  8 06:54:01 2025] NET: Registered PF_BLUETOOTH protocol family
[Sat Mar  8 06:54:01 2025] Bluetooth: HCI device and connection manager initialized
[Sat Mar  8 06:54:01 2025] Bluetooth: HCI socket layer initialized
[Sat Mar  8 06:54:01 2025] Bluetooth: L2CAP socket layer initialized
[Sat Mar  8 06:54:01 2025] Bluetooth: SCO socket layer initialized
[Sat Mar  8 06:54:02 2025] Bluetooth: hci0: Found device firmware: intel/ibt-20-1-3.sfi
[Sat Mar  8 06:54:02 2025] Bluetooth: hci0: Boot Address: 0x24800
[Sat Mar  8 06:54:02 2025] Bluetooth: hci0: Firmware Version: 132-3.24
[Sat Mar  8 06:54:02 2025] Bluetooth: hci0: Firmware already loaded
[Sat Mar  8 06:54:02 2025] Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
[Sat Mar  8 06:54:02 2025] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[Sat Mar  8 06:54:02 2025] Bluetooth: BNEP filters: protocol multicast
[Sat Mar  8 06:54:02 2025] Bluetooth: BNEP socket layer initialized
[Sat Mar  8 06:54:02 2025] Bluetooth: MGMT ver 1.23
[Sat Mar  8 06:54:14 2025] Bluetooth: RFCOMM TTY layer initialized
[Sat Mar  8 06:54:14 2025] Bluetooth: RFCOMM socket layer initialized
[Sat Mar  8 06:54:14 2025] Bluetooth: RFCOMM ver 1.11
[Sat Mar  8 06:54:15 2025] Modules linked in: snd_seq_dummy rfcomm snd_hrtimer snd_seq snd_seq_device af_packet cmac algif_skcipher bnep nls_utf8 nls_cp437 vfat fat iwlmvm snd_soc_dmic snd_soc_acp6x_mach snd_acp6x_pdm_dma snd_sof_amd_acp70 snd_sof_amd_acp63 snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci snd_sof_xtensa_dsp spd5118 mac80211 intel_rapl_msr regmap_i2c snd_sof libarc4 snd_sof_utils snd_pci_ps snd_soc_acpi_amd_match soundwire_amd edac_mce_amd snd_hda_codec_realtek soundwire_generic_allocation edac_core snd_amd_sdw_acpi amd_atl snd_hda_scodec_component soundwire_bus intel_rapl_common snd_hda_codec_generic snd_soc_sdca snd_hda_codec_hdmi snd_soc_core btusb btbcm kvm_amd btintel snd_hda_intel btrtl snd_intel_dspcfg iwlwifi btmtk ac97_bus snd_intel_sdw_acpi snd_pcm_dmaengine kvm bluetooth cfg80211 snd_hda_codec snd_compress rapl snd_rpl_pci_acp6x snd_hda_core snd_acp_pci snd_acp_legacy_common snd_hwdep snd_pci_acp6x wmi_bmof efi_pstore i2c_piix4 snd_pcm snd_ctl_led k10temp i2c_smbus
[Sat Mar  8 07:28:48 2025] Bluetooth: hci0: ACL packet for unknown connection handle 3585
[Sat Mar  8 10:12:36 2025] Bluetooth: hci0: urb 00000000fb00f979 failed to resubmit (2)
[Sat Mar  8 10:12:36 2025] Bluetooth: hci0: Found device firmware: intel/ibt-20-1-3.sfi
[Sat Mar  8 10:12:36 2025] Bluetooth: hci0: Boot Address: 0x24800
[Sat Mar  8 10:12:36 2025] Bluetooth: hci0: Firmware Version: 132-3.24
[Sat Mar  8 10:12:36 2025] Bluetooth: hci0: Firmware already loaded
[Sat Mar  8 10:12:36 2025] Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
[Sat Mar  8 10:12:36 2025] Bluetooth: MGMT ver 1.23
[mattheww@openmandriva-x8664 ~]$ sudo dnf clean all
12 files removed
[mattheww@openmandriva-x8664 ~]$ sudo dnf update kernel-firmware
OpenMandriva Rolling - x86_64                                       780 kB/s | 5.4 MB     00:07
OpenMandriva Rolling - Extra - x86_64                               420 kB/s | 1.4 MB     00:03
OpenMandriva Rolling - Restricted - x86_64                          8.7 kB/s |  24 kB     00:02
OpenMandriva Rolling - Non-free - x86_64                             15 kB/s |  30 kB     00:02
Dependencies resolved.
Nothing to do.
Complete!
Did you compile your own kernel to get a kernel that is not released yet?
Nope. I just installed this yesterday from a USB stick and did the updates. Perhaps it came from one of the other repos I checked in the welcome screen?
This is way over my head. :smiley:
You should have some or all of these.
rpm -qa | grep firmware
radeon-firmware-20241110-1.noarch
nvidia-firmware-20241110-1.noarch
kernel-firmware-extra-20241110-1.noarch
kernel-firmware-20241110-1.noarch
sof-firmware-2025.01-1.noarch
There is no linux-firmware package in OMLx.
As I recall there was a dsync that somehow installed kernel-rc-desktop, I reported this in OM-Chat but do not recall anyone looking in to this. This is a release candidate kernel not from the stable line. They usually work very well in my experience. But they are in repos for testing not for non-technical users/testers.
@Matt you can try booting into kernel-desktop-6.13.5-1 but I doubt that will help.
Bluetooth works for me but my hw is different. I am not even sure which of these are bluetooth packages.
$ rpm -qa | grep blue
lib64bluez3-5.79-1.znver1
bluez-5.79-1.znver1
pulseaudio-module-bluetooth-17.0-1.znver1
kf6-bluez-qt-6.11.0-1.znver1
plasma6-bluedevil-6.3.2-1.znver1
I have all of these:
Here is how to post code.
Thanks. Booting into a different Kernal is beyond my knowledge. I’m not even sure how to downgrade, but perhaps that would be a solution?
OM sees the Bluetooth, recognizes the adapter, but still only shows Mac addresses. I’m super confused.
Thank you for the code posting tip.
Run this command, you probably already have 6.13.5-1:
rpm -qa | grep kernel
You should be able to boot in to that kernel and then run this:
sudo dnf rm kernel-rc-desktop.
Then you will be booting into the regular or default kernel-desktop.
Ok, I booted into 6.13-5-1 and no dice there either.
Now we are the “I don’t know” stage. You should have these modules loaded:
lsmod | grep bluetooth
bluetooth             696320  44 btrtl,btmtk,btintel,btbcm,bnep,btusb,rfcomm
rfkill                 32768  10 iwlmvm,asus_wmi,bluetooth,cfg80211
ecdh_generic           16384  3 bluetooth,tpm
If you do then my guess is this is hardware related. Possibly something about your bluetooth hw is to new to be in Linux kernel. You might get better help at OM-Chat.
