Automatic login. (Checkbox not there)
OpenMandriva Lx 25.04 (ROME) Rolling x86_64
KDE
I do not seem to see the automatic login checkbox in the setup user screen.
Most OM instructions say to check this if you want a user to automatically login at startup.
Has this feature been moved?
Is there a way I can set it up in the command line?
Is this in the USB installer?
This is on a machine where I have successfully installed OM.
It is to function as a server and when I reboot I want it to go directly to the desktop without having to log in.
Thanks. That worked. I never would have thought to look under “Colors & Themes” :roll_eyes:
Indeed. That’s such a weird location.
