Automated Backup Software That Supports S3 Storage
Is there any software that can do automated backups to an S3 bucket? I’ve been digging around in the package manager but I haven’t found anything yet.
Back on Ubuntu I used to use Duplicati but that’s not available on OM-Rome.
I looked into mounting an S3 bucket as a drive, but s3fs doesn’t seem to be in the repos either.
Thanks,
Alexander
Welcome!
You would have to create a github account, if you don’t have one, but you can put in package requests and file bug reports here.
From their website I see that Duplicati has a docker image available if you’re familiar with docker. They also have a fedora rpm that may or may not work here, and a generic zip file.
I do not use Duplicati or Docker, so this is all the info I can offer.
Thanks for the advice Lee. I tried the RPM but it did not work. I have used Docker a little bit in the past.
Right now I’m thinking I may install Duplicati on my Pihole VM which runs Ubuntu Server, and then mount my samba share on it.
I keep our important files on a TrueNAS server, I’m just working on the remote backup part of the equation in case of fires, theft, etc.
KopiaUI claims to support s3 connection but it does not work. When trying to create a repo it returns:
Connect Error: INTERNAL: internal server error: connect error: unable to write blobcfg blob: PutBlob() failed for “kopia.blobcfg”: unable to complete PutBlob(kopia.blobcfg) despite 10 retries: The specified key does not exist.
