Ciao
da sempre ho utilizzato Audacity per la manipolazione dell’audio.
Da quando sono passato a OMV LX3.0 ottengo questo errore
$ audacity
17:53:17: Warning: Mismatch between the program and library build versions detected.
The library used 3.0 (wchar_t,compiler with C++ ABI 1010,wx containers,compatible with 2.8),
and wxCore used 3.0 (wchar_t,compiler with C++ ABI 1002,wx containers,compatible with 2.8).
and wxQA used 3.0 (wchar_t,compiler with C++ ABI 1002,wx containers,compatible with 2.8).
and wxHTML used 3.0 (wchar_t,compiler with C++ ABI 1002,wx containers,compatible with 2.8).
and wxAdvanced used 3.0 (wchar_t,compiler with C++ ABI 1002,wx containers,compatible with 2.8).
and your program used 3.0 (wchar_t,compiler with C++ ABI 1009,wx containers,compatible with 2.8).
Errore di segmentazione (core dump creato)
Qualche suggerimento?
